[Mapserver-users] Problems configuring Mapserver on SuSE Linux 9.0
woodbri at swoodbridge.com
Sun Feb 15 11:03:25 EST 2004
Christian,
I have never used SuSE so this might not apply, but on other
distributions you have to install a dev package also to get the
include files.
So if you package name for gd is like gd2 then try installing gd2-dev
also and see if that helps.
-Steve
On 15 Feb 2004 at 15:51, Christian Lindner wrote:
> Hello,
> I am having problems configuring Mapserver for use on my test server
> running SuSE Linux 9.0. I am a Linux novice so I've chosen SuSE Linux
> because like Redhat it is a distribution which has many components
> preconfigured and already installed. In my case the 'gd' library used by
> Mapserver is already existent on my machine. So it should be found by
> 'configure'. But instead 'configure' returns a message that gd.h or
> libgd.a/libgd.so could not be found. I have located a file called
> 'libgd.so.2' in /usr/lib but running 'configure --with-gd=/usr/lib'
> brings up the same error message (since there is none of the files
> needed).
> What am I to do?
> Many thanks for you help.
> Best Regards,
> Chris
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
