[Mapserver-users] Mapserver - Oracle through OGR
bartvde at xs4all.nl
Mon Feb 16 05:42:31 EST 2004
Hi list,
I am trying to connect Mapserver to Oracle through OGR but I am running
into a problem. Error message, output from ogrinfo and excerpt from MAP
file at the bottom of this e-mail. We can connect through the native
Oracle Spatial interface of Mapserver on the same machine.
Anybody have an idea what could be the problem?
Thanks in advance,
Bart
msDrawMap(): Image handling error. Failed to draw layer named 'straten'.
msOGRFileOpen(): OGR error. Open failed for OGR connection
`OCI:laura/laura at laura'. File not found or unsupported format.
When I connect through ogrinfo there are no problems, this is part of the
output generated by ogrinfo:
INFO: Open of `OCI:laura/laura at laura'
using driver `OCI' successful.
Layer name: SELECT * from straten where name='Kerkstraat'
Geometry: Unknown (any)
Feature Count: 809
Extent: (19361.400000, 309014.500000) - (276658.600000, 603186.200000)
Layer SRS WKT:
(unknown)
FRC: Integer (9.0)
NAMELC: String (3.0)
ROUTENUM: String (50.0)
MI_SYMBOLOGY: String (254.0)
MI_PRINX: Integer (11.0)
OGRFeature(SELECT * from straten where name='Kerkstraat'):0
ID (Integer) = 2079166603
FRC (Integer) = 7
NAME (String) = Kerkstraat
NAMELC (String) = DUT
ROUTENUM (String) = (null)
MI_SYMBOLOGY (String) = (null)
MI_PRINX (Integer) = 312
LINESTRING (268161.900 566095.100,268074.900 566072.700)
This is the relevant part of my MAP file:
NAME "STRATEN"
CONNECTIONTYPE OGR
CONNECTION "OCI:laura/laura at laura"
DATA "SELECT * FROM STRATEN where name='Kerkstraat'"
TYPE LINE
No errors in the Apache error log.
