[Mapserver-users] WMS Client Problem
bartvde at xs4all.nl
Mon Feb 16 11:25:36 EST 2004
Hi Stefan,
I had the exact same problem (and still have, because we have changed
things in the firewall/proxy to solve this).
I think you need to recompile Mapserver and libcurl to have it going
through the proxy. Not a totally trivial task.
I think it would be a nice enhancement to Mapserver if we could specify in
the MAP file whether or not the WMS client needs to go through a proxy and
then the address/URL of the proxy. Also some kind of authentication
support for the WMS client would be nice.
Best regards,
Bart
> Dear List,
> I'm using MapServer 4.0 under winnt 4.0 with apache
> 1.3.27.
> When I'm trying to get a WMS connection as client to
> an OGC conform WMS Server,
> I don't get any map back.
> Part of the Mapfile
> LAYER
> NAME "Germany"
> TYPE raster
> STATUS ON
> DEBUG ON
> CONNECTIONTYPE WMS
> CONNECTION
> "http://wms.ccgis.de/umn/bin/mapserv.exe?map=d:/umn/germany.map&"
> METADATA
> "wms_title" "Germany"
> "wms_server_version" "1.1.0"
> "wms_srs" "EPSG:4326 EPSG:31493"
> "wms_name" "Germany"
> "wms_format" "image/png"
> "wms_connectiontimeout" "60"
> END
> END
> Part from the MS_ERRORFILE:
> msDrawWMSLayerLow(): WMS server error. WMS GetMap
> request failed for layer 'Germany' (Status -28:
> TIMEOUT of 30 seconds exceeded.).
> msHTTPExecuteRequests(): HTTP request error. HTTP:
> request failed with curl error code 7 (Failed connect
> to 212.79.172.110:80, errno: 0) for
> http://wms.ccgis.de/umn/bin/mapserv.exe?map=d:/umn/germany.map&SERVICE=WMS&VERSION=1.1.0&LAYERS=Germany&FORMAT=image%2Fpng&TRANSPARENT=TRUE&STYLES=&REQUEST=GetMap&WIDTH=550&HEIGHT=370&SRS=EPSG:4326&BBOX=7.533066,53.305070,12.090253,55.101040&EXCEPTIONS=application/vnd.ogc.se_inimage
> request failed for layer 'Germany' (Status -7: Failed
> connect to 212.79.172.110:80, errno: 0).
> In the IMAGEPATH there are files like
> 10769407406700.img.tmp
> My Client is behind a Firewall (Proxy) and if i try
> the Connection with GetCapabilities or GetMap directly
> as URL in a Browser I get a correct response.
> If anybody can give me a hint?
> Thanks in advance for your help.
> Stefan Schneberger
> Mit schönen Grüßen von Yahoo! Mail - http://mail.yahoo.de
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
