[Mapserver-users] ms_newclassObj
robert fritz
robert-fritz at web.de
Wed Feb 18 05:38:19 EST 2004
Hello,
In my map file I have defined a layer with 1 class. I add a new class using mapscript and set an expression for this new layer. As a result I get a new entry in my legend, but the shape of the new class is not drawn. The expression is correct!
If I define an empty second class (class end) in my map file and set the expression (the same as above) and the style for this class using mapscript I get what I want the shape is drawn.
I want to create the class with mapscript and I do not want to use a predefined emtpy class in the map file. What do I do wrong?
Mapserver 4.0
Thank you.
$layerO->set(classitem,$qitem);
$classO = ms_newclassobj($layerO); // this does not work
//$classO=$layerO->getclass(0); // this works,
$classO->set(name,"TEST_OM");
$styleO = ms_newStyleObj($classO);
$styleO->color->setRGB(255,255,0);
$styleO->outlinecolor->setRGB(0,0,0);
//$styleO->set(symbolname,"dashed1");
$query=$msom_value;
echo($query);
$classO->setExpression("\"$query\"");
______________________________________________________________________________
... and the winner is... WEB.DE FreeMail! - Deutschlands beste E-Mail
ist zum 39. Mal Testsieger (PC Praxis 03/04) http://f.web.de/?mc=021191
