[Mapserver-users] Changing PostGIS connection string on the fly
Jan Hartmann jhart at frw.uva.nl
Wed Feb 18 08:31:54 EST 2004
David Mitchell wrote:
> I have a layer that connects to a postgis datasource. In a file with ~30
> layers, it can get tedious having to go through every layer and change
> the connection string by hand (yes, search and replace works fine, but
> there has to be a better way). I want to be able to set the connection
> string dynamically.
> I've tried using the cgi variable like so:
> ...&map_water_connection=%22user=postgres+dbname=world+host=dbserver%22
> and in a number of variations on the theme, but to no avail. Ideas?
I'm not sure if the problem lies in the CONNECTION string. The "DATA"
statement is protected in the newer releases of MapServer: you have to
set a DATAPATTERN to change DATA by a CGI variable. This was done for
security reasons. I don't think the same was done for "CONNECTION"
although is would make sense to do so. Anyway, try setting DATAPATTERN
to .* in the MAP section of your MapFile. This will make the DATA
statement accessible for every possible change by a CGI variable and
perhaps it will solve your problem too.
Jan
