[Mapserver-users] Problem: processTemplate()
Lowell Filak
lfilak at medinaco.org
Wed Feb 18 09:45:48 EST 2004
What version are you using - it could be the call has changed from what
the documentation shows.
Lowell
The following message was sent by Janett Jahn
<jjahn at et-inf.fho-emden.de> on Wed, 18 Feb 2004 12:23:04 +0100.
> I have a problem when I am using the processTemplate() function from perl
> mapscript.
> The function returns :
> Type error in argument 3 of mapObj_processTemplate. Expected _p_pchar at
> ./myfile.pl line 42.
> my code :
> my @tnames = keyes(%tags);
> my @tvalues = values(%tags);
> my $temp =
> $map->processTemplate($mapscript::MS_TRUE,\@tnames,\@tvalues,$#tnames
+1);
> I know that there was the same question on 09.08.2002 and I read the
answer
> (10.08.2002) too.
> I installed SWIG version 1.1 and append the lines to typemaps.i .
> When I run "swig -shadow -perl5 mapscript.i" I get many errors in
mapscript.i.
> Then I removed SWIG version 1.1 and installed the newest (1.3.21).
> I appended these lines and run swig again. Then I got 2 warnings :
> "Depracated typemap feature ($source/$target)..."
> I changed the lines as follows :
> %module argv
> // This tells SWIG to treat char ** as a special case
> %typemap(perl5,in) char ** {
> AV *tempav;
> I32 len;
> int i;
> SV **tv;
> if (!SvROK($input))
> croak("$input is not a reference.");
> if (SvTYPE(SvRV($input)) != SVt_PVAV)
> croak("$input is not an array.");
> tempav = (AV*)SvRV($input);
> len = av_len(tempav);
> $1 = (char **) malloc((len+2)*sizeof(char *));
> for (i = 0; i <= len; i++) {
> tv = av_fetch(tempav, i, 0);
> $1[i] = (char *) SvPV(*tv,PL_na);
> $1[i] = 0;
> // This cleans up our char ** array after the function call
> %typemap(perl5,freearg) char ** {
> free($input);
> // Creates a new Perl array and places a char ** into it
> %typemap(perl5,out) char ** {
> AV *myav;
> SV **svs;
> int i = 0,len = 0;
> /* Figure out how many elements we have */
> while ($1[len])
> len++;
> svs = (SV **) malloc(len*sizeof(SV *));
> for (i = 0; i < len ; i++) {
> svs[i] = sv_newmortal();
> sv_setpv((SV*)svs[i],$1[i]);
> myav = av_make(len,svs);
> free(svs);
> $result = newRV((SV*)myav);
> sv_2mortal($result);
> After that I run swig again and there were no errors or warnings and so I
> compiled the perl- mapscript.
> But I still get the same error, when I try to run my perlsript.
> Can someone help me ???
> (sorry for my bad english)
> This mail sent through IMP: http://horde.org/imp/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
