[Mapserver-users] Problem with WFS
Van Ulden, Joost
jvanulde at nrcan.gc.ca
Wed Feb 18 16:16:24 EST 2004
We also have the same problem. When we check with an HTTP Sniffer, ArcMap
never makes the GetFeature Request. Not sure what is happening. If you try
to load MapServer GML into ArcMap you also get an error. We have come to
the same conclusion as Bart. Hopefully, ESRI will address this soon!
Cheers,
Joost van Ulden
Programmer/Analyst
Natural Resources Canada / Ressources naturelles Canada
Geological Survey of Canada / Commission geologique du Canada
101 - 605 Robson Street / 101 - 605 rue Robson
Vancouver, B.C. / Vancouver (C.-B.)
V6B 5J3
Office/Bureau: 604.666.7525
fax/telecopieur: 604.666.1124
> -----Original Message-----
> From: Bart van den Eijnden [mailto:bartvde at xs4all.nl]
> Sent: Wednesday, February 18, 2004 10:00 AM
> To: Florian Jurgeit; mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Problem with WFS
> Hi,
> I've encountered the same problem.
> My guess is that the ESRI GML parser expects the GML to be
> similar to what
> the ESRI WFS produces, and this is a bit different from the
> Mapserver GML.
> So my guess is that the ESRI GML parser is a bit too tight.
> Some differences are:
> -Mapserver uses <wfs:FeatureCollection> as the root element,
> ESRI uses
> <Features>
> -Mapserver uses by default MS_GEOMETRY for the "spatial attribute"
> (although it can be changed), ESRI uses _SHAPE_
> You could try using _SHAPE_ instead of MS_GEOMETRY in Mapserver WFS.
> Anyway, it still is a guess because I don't know the ESRI internals.
> BTW: is this the maximum debug/log level you can get in ArcMap?
> Best regards,
> Bart
> On Wed, 18 Feb 2004 14:27:17 +0100, Florian Jurgeit
> <Florian.Jurgeit at uibk.ac.at> wrote:
> > When trying to load WFS data in ArcMAP the error "Unable to
> parse WFS
> > data" occures.
> > The WFS service is done by an UMN MapServer - the Output
> looks OK in
> > the
> > Browser.
> > Getting the List of Layers works in ArcMAP - just opening
> one does not
> > work (pasring error - Why ?)
> > Greatings from Austria,
> > Flo
> > The WFS-Code looks that way (in the Browser): (only frist
> element ...)
> > <?xml version="1.0" encoding="ISO-8859-15" ?>
> > - <#> <wfs:FeatureCollection xmlns="*http://www.ttt.org/myns*"
> > xmlns:myns="*http://www.ttt.org/myns*"
> > xmlns:wfs="*http://www.opengis.net/wfs*"
> > xmlns:gml="*http://www.opengis.net/gml*"
> > xmlns:xsi="*http://www.w3.org/2001/XMLSchema-instance*"
> > xsi:schemaLocation="*http://www.opengis.net/wfs
> http://ogc.dmsolutions.ca/wfs/1.0.0/WFS-basic.xsd/wfs/1.0.0/WF
> S-basic.xsd
> http://XXX.XXXX.ac.at/cgi-bin/mapserv?map=/home/cXXXXXX/public
> _html/ta_map/ta_wfs.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=Desc
ribeFeatureType&TYPENAME=g1gem*">
> > - <#> <gml:boundedBy>
> > - <#> <gml:Box srsName="*EPSG:32632*">
> > <gml:coordinates>550953.125000,137001.765625
> > 817651.250000,287281.500000</gml:coordinates>
> > </gml:Box>
> > </gml:boundedBy>
> > - <#> <gml:featureMember>
> > - <#> <g1gem>
> > <COUNT>1</COUNT>
> > <ID>120307</ID>
> > <TYP>gem</TYP>
> > <LEVEL>800</LEVEL>
> > <GEM_NAME>Kötschach-Mauthen</GEM_NAME>
> > - <#> <MS_GEOMETRY>
> > <gml:coordinates>797267.125000,168217.484375
> > 811924.625000,182463.218750</gml:coordinates>
> > </gml:Box>
> > </gml:boundedBy>
> > - <#> <gml:Polygon srsName="*EPSG:32632*">
> > - <#> <gml:outerBoundaryIs>
> > - <#> <gml:LinearRing>
> > <gml:coordinates>805507.500000,180764.437500
> > 807767.625000,180515.187500 808255.562500,180119.078125
> > 808718.125000,179930.078125 808993.125000,179923.187500
> > 809386.562500,180023.078125 809839.187500,179958.812500
> > 810139.062500,180029.484375 810649.250000,180029.546875
> > 810483.500000,179581.343750 809828.750000,178621.031250
> > 809631.500000,178581.078125 809388.187500,178248.906250
> > 809160.187500,178202.250000 809046.500000,178246.109375
> > 808988.875000,178182.781250 809021.375000,177865.812500
> > 809233.875000,177592.843750 809185.687500,177430.812500
> > 809116.500000,177394.921875 809127.000000,177295.265625
> > 809048.812500,177276.921875 808989.250000,177120.265625
> > 809022.750000,177021.875000 808947.875000,176925.531250
> > 809001.312500,176483.406250 808917.750000,176053.781250
> > 808629.937500,175764.265625 809191.812500,175409.312500
> > 810011.125000,175166.765625 810812.125000,175129.703125
> > 811762.062500,174990.578125 811677.187500,174365.406250
> > 811725.875000,174173.625000 811602.625000,173317.781250
> > 811385.687500,172742.484375 811319.312500,172709.750000
> > 811163.062500,171524.312500 811316.937500,170842.125000
> > 811693.187500,170398.718750 811430.000000,169716.625000
> > 811924.625000,168801.953125 811668.187500,168722.312500
> > 811340.750000,168766.875000 811159.187500,168480.953125
> > 810874.187500,168458.562500 810442.750000,168403.250000
> > 810246.750000,168243.109375 810013.312500,168217.875000
> > 809697.500000,168395.343750 808889.250000,168217.484375
> > 808531.625000,168358.187500 808449.062500,168511.015625
> > 808121.812500,168774.453125 808086.312500,168663.718750
> > 807707.437500,168799.984375 807069.437500,168517.265625
> > 806679.187500,168775.859375 806478.312500,168772.593750
> > 806170.062500,168638.468750 805965.250000,168632.125000
> > 805896.312500,168453.750000 805452.812500,168404.218750
> > 805027.875000,168590.343750 804813.437500,168491.406250
> > 804581.500000,168658.359375 804380.500000,168619.312500
> > 804361.375000,168771.343750 804123.875000,168745.015625
> > 803944.812500,168928.156250 803608.062500,168841.109375
> > 803239.375000,169012.812500 803045.375000,168936.406250
> > 803004.437500,168809.546875 802791.500000,168789.718750
> > 802769.187500,168613.250000 802635.312500,168510.640625
> > 801560.437500,169092.500000 801428.437500,169323.406250
> > 801040.625000,169349.796875 800246.312500,169140.734375
> > 799805.625000,169241.640625 799401.000000,168972.437500
> > 798614.375000,169096.406250 798130.000000,168846.343750
> > 797938.437500,168859.109375 797944.437500,169402.171875
> > 798106.125000,170196.890625 798086.625000,170423.343750
> > 797781.750000,170990.890625 798162.062500,172057.250000
> > 797911.312500,172078.515625 797862.500000,172273.281250
> > 797678.625000,172553.828125 797680.625000,172790.468750
> > 797839.812500,173412.656250 798014.187500,173449.328125
> > 798392.562500,173677.640625 798659.187500,174277.687500
> > 798746.875000,174578.187500 798699.312500,175641.031250
> > 798913.062500,176346.421875 798780.375000,176844.265625
> > 798668.187500,176861.140625 798678.437500,177093.234375
> > 798586.625000,177212.468750 798635.437500,177345.453125
> > 798581.437500,177434.687500 798495.125000,177435.953125
> > 798431.687500,177550.734375 798233.062500,177553.812500
> > 798018.500000,177445.765625 797876.562500,177602.312500
> > 797789.812500,177831.078125 797742.437500,177980.812500
> > 797938.562500,178386.531250 798041.937500,178475.421875
> > 798189.000000,178480.531250 798339.437500,178642.171875
> > 798415.187500,178941.031250 798315.000000,179121.937500
> > 798374.000000,179251.484375 798137.250000,179728.546875
> > 798173.750000,179865.875000 797999.625000,180060.750000
> > 797885.187500,180355.125000 797684.000000,180567.546875
> > 797619.687500,180552.984375 797571.187500,180905.125000
> > 797507.625000,180912.640625 797408.687500,181125.687500
> > 797353.500000,181126.656250 797345.437500,181236.468750
> > 797267.125000,181257.203125 797899.312500,182006.718750
> > 797853.125000,182463.218750 798239.937500,182355.265625
> > 798428.625000,182096.046875 798459.437500,181919.343750
> > 799039.500000,181669.687500 799844.437500,181778.218750
> > 801606.000000,182278.328125 802187.500000,182349.484375
> > 802352.250000,182269.375000 802645.437500,182260.484375
> > 802723.437500,182336.953125 803011.375000,182404.953125
> > 803051.937500,182195.703125 803435.562500,182110.609375
> > 803918.750000,181764.390625 804157.062500,181805.593750
> > 804800.812500,181292.812500 804995.312500,181000.812500
> > 805246.625000,180951.531250
> 805507.500000,180764.437500</gml:coordinates>
> > </gml:LinearRing>
> > </gml:outerBoundaryIs>
> > </gml:Polygon>
> > </MS_GEOMETRY>
> > </g1gem>
> > </gml:featureMember>
> > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
