[Mapserver-users] Tricky bug: any hints ?
Daniel FAIVRE
daniel.faivre at camptocamp.com
Thu Feb 19 11:14:43 EST 2004
Hello,
I've faced a tricky bug with some PostGIS layers and MapServer. I'm
using MapServer from CVS (040213), php mapscript, php 4.3.4, and
PostgreSQL 7.4 on a Debian woody.
I've got a postgis layer with 50000 streets (no dump joined, see table
def at the end of this message). These layer is a MULTILINESTRING layer,
with simple and valids geometries with 1 as numgeometries (all
geometries are LINESTRINGs).
When I try to classify this layer as reported below, I get a bug
(Probably a MapServer one). Nothing is reported by PostGreSQL debug,
except a "LOG: 08P01: unexpected EOF on client connection" ...
Apache only report: [Thu Feb 19 16:51:38 2004] [error] [client
127.0.0.1] Premature end of script headers: /usr/lib/cgi-bin/php
The bug seem to relate to multiple styles for one class.
Here is a mapfile extraction, with comments about how to produce or
avoid the bug:
LAYER
NAME "streets"
TYPE LINE
CONNECTIONTYPE postgis
CONNECTION "user=my_user_name dbname=my_db_name"
DATA "the_geom from streets"
STATUS ON
TRANSPARENCY 80
TEMPLATE "ttt"
HEADER "link_id st_name"
CLASSITEM "route_type"
CLASS
EXPRESSION /[123]/
NAME "Routes principales"
STYLE
COLOR 64 0 0
SYMBOL "line1"
SIZE 5
END
STYLE
COLOR 255 196 0
SYMBOL "line2"
SIZE 3
END
LABEL
ANTIALIAS true
ANGLE AUTO
FONT verdana
MINDISTANCE 1
BUFFER 20
TYPE truetype
COLOR 0 0 0
OUTLINECOLOR 255 255 255
SIZE 6
MINSIZE 6
MAXSIZE 10
POSITION auto
END
END
CLASS
EXPRESSION "4"
NAME "Routes secondaires"
STYLE
COLOR 64 0 0
SYMBOL "line1"
SIZE 4
END
STYLE
COLOR 255 64 0
SYMBOL "line2"
SIZE 2
END
LABEL
ANTIALIAS true
ANGLE AUTO
FONT verdana
MINDISTANCE 1
BUFFER 20
TYPE truetype
COLOR 0 0 0
SIZE 6
MINSIZE 6
MAXSIZE 8
POSITION auto
END
END
CLASS
NAME "Autres"
EXPRESSION /[95]/
STYLE
COLOR 96 96 96
SYMBOL "line1"
SIZE 2
END
# STYLE # second style commented to avoid the bug with
type 9: no bug with this part commented
# COLOR 64 255 0
# SYMBOL "line2"
# SIZE 1
# END
END
TOLERANCE 5
TOLERANCEUNITS pixels
END
When the commented part is uncommented, the bug happens. In this case,
when EXPRESSION /[95]/ is replaced by EXPRESSION /5/, no bug happens ...
Furthermore, when I start my application with the commented part, make a
zoom, and a query, I can uncomment this style part aned refresh my page
without a bug !
I've search about something related to my data set, but I could not have
found anything. All my LINESTRING GEOMETRIES are simples, valid, and
report 1 as numgeometries ...
Does anybody see any hint ? Is it really a MapServer bug related to
multiple styles on the same line ?
Best regards,
Daniel FAIVRE
Here is my very simple table def:
CREATE TABLE public.streets
link_id int8,
st_name varchar,
route_type varchar,
the_geom public.geometry,
CONSTRAINT "$1" CHECK srid(the_geom) = -1,
CONSTRAINT "$2" CHECK geometrytype(the_geom) = 'MULTILINESTRING'::text
OR the_geom IS NULL
) WITH OIDS;
