[Mapserver-users] Raster with SVG output in Mapserver 4.1 dev
Steve Lime steve.lime at dnr.state.mn.us
Thu Feb 19 11:51:53 EST 2004
You can get one layer at a time using the method you mention. Has this been a problem?
As for rasters, I would look at MapServer just as an image engine. Generate the SVG independently of the raster layer and use a call to MapServer from within the SVG (e.g. src=/cgi-bin/mapserv?map=...&mode=map) to get the layer you need as a GIF, PNG or JPEG image.
Steve
>>> yuth hor <mofumyke at yahoo.com> 2/12/2004 5:35:10 AM >>>
Hi all
Now, I have tested SVG output from the nightly build of Mapserver 4.1. It quite stable and work fine. Our test application, in this case, we will use Mapserver only as a SVG generator by request through CGI. My question is
-        Can we request each SVG layers by specify the layer name? (now we have to request one CGI statement as one SVG layer for example,
http://host/cgi-bin/mapserv_41.exe?map=D:\apache_group\Apache\htdocs\umn2svg\test.map& mode=nquery& qlayer=water  à return water layer
http://host/cgi-bin/mapserv_41.exe?map=D:\apache_group\Apache\htdocs\umn2svg\test.map& mode=nquery& qlayer=contour  à return contour layer
But if we didn't specify qlayer="" it will return all layer in the mapfile
-        Can we enclose the Raster image that generate by Mapserver from tmp directory together with the svg output?
I try to do but it not success. No image in the tmp directory.
----CGI request---
http://host/cgi-bin/mapserv?map=/usr/local/apache/htdocs/umn2svg/trysvgimage.map&mode=nquery&qlayer=ndvi
---- SVG return error ----
"mismatched tag: line6, column2"
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.0//EN"    "http://www.w3.org/TR/2001/REC-SVG-20010904/DTD/svg10.dtd" [
<svg>
<!-- this is the start of a layer -->
<g >
<image width="468" height="420" id="testsvg_Image_1_" xlink:href="../tmp/test10765838246078.jpg" />
</g>
<!-- this is the end of a layer -->
</svg>
---- mapfile ---
MAP
  NAME 'test'
  EXTENT 325704 620898 1213325 2263428
  SIZE 800 600
  STATUS ON
  UNITS METERS
IMAGETYPE JPEG
  WEB
    HEADER 'iheader.svg'
    FOOTER 'ifooter.svg'
    QUERYFORMAT 'image/svg+xml'
    IMAGEPATH "/usr/local/apache/htdocs/tmp/"
    IMAGEURL "../tmp/"
  END
    LAYER
        NAME ndvi
        STATUS DEFAULT
        DATA 'sptindex'
        TYPE QUERY
        HEADER image_header.svg
        FOOTER image_footer.svg
        TEMPLATE image.svg
  END
END
Anyone can give me some light?
Thanks
Teerayut Horanont
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online
