[Mapserver-users] Bread and Butter
Eduardo Spremolla
edspremolla at Antel.com.uy
Fri Feb 20 09:46:14 EST 2004
in bash do:
export PATH=/bla.bla.bla:/etc....
export LD_LIBRARY_PATH=/your_libs/path:/more/libs
El vie, 20-02-2004 a las 10:50, scoota at supanet.com escribió:
> Hi All,
> I'm sure this is bread and butter to all the UNIX gurus, but it would save a lot of head scratching on my part. This relates back to a problem I had installing MapServer on a Solaris. The suggested fix was to ensure the GNU tools were used in the make. Some details were given about this but I'm still a little unclear. For instance, how do I change the search path / environment variable. Using setenv LD_LIBRARY_PATH = mypath was mentioned somewhere. I'm told setenv is a command in the C shell, however, I'm set up to use bash. Is there an equivalent in bash? Also mentioned was changing the .bashrc file - where will I find this file?
> Thanks for any help offered.
> Keith
Eduardo Spremolla <edspremolla at antel.com.uy>
Antel I+D
