[Mapserver-users] asymmetric lines
Stepan Kafka
stepan.kafka at centrum.cz
Mon Feb 23 05:05:05 EST 2004
Excuse me, it must be oposite:
OFFSET 5 -99
Stepan
> -----Pùvodní zpráva-----
> Od: youssef chamoun [mailto:youssefchamoun at hotmail.com]
> Odesláno: 23. února 2004 10:04
> Komu: stepan.kafka at centrum.cz; mapserver-users at lists.gis.umn.edu
> Pøedmìt: RE: [Mapserver-users] asymmetric lines
> Hi Stephan,
> I really appreciate your reply.
> I tried the OFFSET -99 5 but mapserver gave an error and did not
> display any
> image. I tried to look for the OFFSET word in the documantation
> but I could
> find it only for the LABEL object. Can you please give me a more detailed
> explanation?
> Thank you again for your help
> youssef
> >From: "Stepan Kafka" <stepan.kafka at centrum.cz>
> >To: "youssef chamoun"
> ><youssefchamoun at hotmail.com>,<mapserver-users at lists.gis.umn.edu>
> >Subject: RE: [Mapserver-users] asymmetric lines
> >Date: Mon, 23 Feb 2004 09:06:57 +0100
> >Hi Youssef,
> > you may use two approaches:
> >1) offset lines. If you set OFFSET -99 <number> (eg -99 5) for line
> >symbols,
> >the result line is parallel to original one. Stacking symbols
> with multiple
> >STYLEs you can achieve desired effect. (There is only simple (but quick)
> >algorithm used for offseting, so there may be some problems with very
> >tortuous lines)
> >2) Truetype symbols. If you set GAP < 0 (eg. GAP -15), the symbols are
> >oriented in "as digitized" orientation. Then you may set
> POSITION (UC, LC,
> >UR, ..) to get different drawing effects.
> >These functionality is available from 3.6.0 (?) version.
> >Stepan Kafka
> > > Od: mapserver-users-admin at lists.gis.umn.edu
> > > [mailto:mapserver-users-admin at lists.gis.umn.edu]za u¾ivatele youssef
> > > chamoun
> > > Odesláno: 20. února 2004 16:33
> > > Komu: mapserver-users at lists.gis.umn.edu
> > > Pøedmìt: [Mapserver-users] asymmetric lines
> > > Hello,
> > > can anyone please help me on a way to create asymmetric lines?
> > > Thank you.
> > > Youssef Chamoun
> > > _________________________________________________________________
> > > Protect your PC - get McAfee.com VirusScan Online
> > > http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Add photos to your messages with MSN 8. Get 2 months FREE*.
> http://join.msn.com/?page=features/featuredemail
