[Mapserver-users] Problem to show a raster layer?
Stephen Clark
stephen.clark at focus.ca
Mon Feb 23 11:35:48 EST 2004
Try something like the following:
LAYER
NAME a69_layer
DATA "d:/to/some/path/a69.tif"
TYPE RASTER
STATUS ON
# turn off the black background in the image files if you have one or just
comment out
OFFSITE 0 0 0
END
Note I use forward slashes in my paths.
I also see you are adding a RASTER file inside a POLYGON layer.
You should use two layers --- one for polgons and one for rasters.
hope this helps
Stephen
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Saturday, February 21, 2004 12:10 AM
Subject: [Mapserver-users] Problem to show a raster layer?
> Sorry i am new in mapserver... i want to show a raster layer but i can't,
> i'm using mapserver 4.0 and windows binaries and phpmapscript
> my raster is a69.tif, it has a tfw file with this information
> 10.3352258255599
> 0
> 0
> -10.3401980506
> 461745.077948169
> 2076516.13845759
> the map file has a simple polygon shapefile an also i want to show raster
> file
> but my problem is that my layer doesn't show.
> its possible to use jpg or pgn like symbols or reference imagenes.
> could you help me?
> MAP
> NAME PRIMERMAPA
> IMAGETYPE PNG
> #STATUS on
> SIZE 400 350
> UNITS METERS
> SYMBOLSET "c:\\program
> files\\nusphere\\apache\\nsdocs\\mapa_siciem\\etc\\symbols.sym"
> FONTSET "c:\\program
> files\\nusphere\\apache\\nsdocs\\mapa_siciem\\etc\\fonts.list"
> EXTENT 448203.823337231 2026726.16845977 538509.467913451 2115325.67281802
> IMAGECOLOR 168 168 168
> SHAPEPATH "c:\\program files\\nusphere\\apache\\nsdocs\\mapa_siciem\\"
> WEB
> #MINSCALE 2000
> #MAXSCALE 1500000
> IMAGEPATH "c:\\program files\\nusphere\\apache\\nsdocs\\tmp"
> IMAGEURL "/tmp"
> END
> LAYER
> NAME morelos
> TYPE POLYGON
> STATUS on
> DATA morelos
> CLASS
> NAME "mpios"
> COLOR 150 230 165
> TEMPLATE void
> OUTLINECOLOR 100 100 70
> END
> TOLERANCE 10
> END
> LAYER # imagen de cartografia
> NAME miraster
> DATA 'relieve.tif'
> STATUS default
> TYPE RASTER
> PROCESSING "BANDS=1,2,3"
> OFFSITE 71 74 65
> END
> END # Fin del mapa
> <?php
> $map_path="mapa_siciem";
> $map=ms_newMapObj($map_path. "\morelos.map");
> $image=$map->draw();
> $testpt->draw($map, $testlayer, $image, 0, " ");
> $image_url=$image->saveWebImage(MS_PNG,1,1,0);
> <HTML>
> <HEAD>
> <TITLE>MAPA </title>
> </head>
> <BODY>
> <img SRC=<?php echo $image_url; ?>>
> </body>
> </html>
> _________________________________________________________________
> Charla con tus amigos en línea mediante MSN Messenger:
> http://messenger.microsoft.com/es
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
