[Mapserver-users] asymmetric lines
woodbri at swoodbridge.com
Mon Feb 23 20:51:10 EST 2004
FYI, there is a bug that I submitted regarding TTF symbols that might
impact this. See
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=573
In summary the symbol flips 180 degrees depending on the angle and
slope of the the line segment.
If you are running into this problem you might want to post a note to
the list or the bug so we know.
Thanks,
-Steve
On 23 Feb 2004 at 9:06, Stepan Kafka wrote:
> Hi Youssef,
> you may use two approaches:
> 1) offset lines. If you set OFFSET -99 <number> (eg -99 5) for line symbols,
> the result line is parallel to original one. Stacking symbols with multiple
> STYLEs you can achieve desired effect. (There is only simple (but quick)
> algorithm used for offseting, so there may be some problems with very
> tortuous lines)
> 2) Truetype symbols. If you set GAP < 0 (eg. GAP -15), the symbols are
> oriented in "as digitized" orientation. Then you may set POSITION (UC, LC,
> UR, ..) to get different drawing effects.
> These functionality is available from 3.6.0 (?) version.
> Stepan Kafka
> > -----P vodn¡ zpr va-----
> > Od: mapserver-users-admin at lists.gis.umn.edu
> > [mailto:mapserver-users-admin at lists.gis.umn.edu]za u ivatele youssef
> > chamoun
> > Odesl no: 20. £nora 2004 16:33
> > Komu: mapserver-users at lists.gis.umn.edu
> > P edm t: [Mapserver-users] asymmetric lines
> > Hello,
> > can anyone please help me on a way to create asymmetric lines?
> > Thank you.
> > Youssef Chamoun
> > _________________________________________________________________
> > Protect your PC - get McAfee.com VirusScan Online
> > http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
