[Mapserver-users] Mapscript causes core dump on Solaris
Lowell Filak
lfilak at medinaco.org
Wed Feb 25 09:44:28 EST 2004
Not a solution but a thought - If the error appears to originate in
libpng it should show it's ugly head via the cgi version and temporarily
take php out of the mix and limiting the points of failure to the
mapserv executable and a mapfile, no?
Lowell
The following message was sent by Carsten Heidmann
<heidmann at Hamburg.BAW.DE> on Tue, 24 Feb 2004 08:54:05 +0100.
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi,
> I had problems running mapscript (4.0.1) applications on Solaris 8
(SPARC).
> Applications developed with the current Maplab version didn't run and
> caused mapscript to terminate with a core dump.
> My current workaround is to disable/delete the lines with ANTIALIAS ... in
> the mapfile.
> I suspect that the basic problem is the usage of a precompiled libpng from
> www.sunfreeware.com. I haven't yet tested compiling libpng by myself but I
> will write if this solves the problem.
> Carsten
> Dipl. Geogr. Carsten Heidmann Bundesanstalt fuer Wasserbau
> Tel.: +49 (0)40 81908-345 - Dienststelle Hamburg -
> Fax: +49 (0)40 81908-373 Wedeler Landstrasse 157
> heidmann at hamburg.baw.de DE - 22559 Hamburg
> http://nokis.baw.de/ http://www.hamburg.baw.de/
> PGP-Key ID: 0xFF489EAE
> PGP-Signatur: http://www.keyserver.net/
> -----BEGIN PGP SIGNATURE-----
> Version: 6.5.8ckt
> iQA/AwUBQDr1ALjxzYr/SJ6uEQJaMQCgm58K71Yqjq3Xp3GoAhl+9i1+CDIAoNKz
> h7o0qlE0XhFi35ZHOqUwhIef
> =hVge
> -----END PGP SIGNATURE-----
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
