[Mapserver-users] SLD questions - How to filter
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Thu Feb 26 09:19:59 EST 2004
A couple of ideas:
1./
- have a 'service' i.e. some CGI script which dynamically generates an SLD
document based on your query, i.e.:
http://remote_server/cgi-bin/mapserv_41.exe?map=PATH/wms.map
&WMTVER=1.0.0
&REQUEST=map
&TRANSPARENT=TRUE
&SRS=EPSG:4326
&BBOX=50,0,170,40
&WIDTH=300
&HEIGHT=150
&FORMAT=PNG
&layers=boundaries
&sld=http%3A//remote_server/cgi-bin/makesld.exe%3FselectedCountry%3DChina
- use the SLD_BODY keyword to pass the entire SLD document (you might want
to use HTTP POST here :))
2./
- setup another mapfile with the SLD as per below as the template, and pass
that output as the SLD to the WMS
Hope this helps.
..Tom
Tom Kralidis
Systems Scientist
Environment Canada
Tel: +01-905-336-4409
http://www.ec.gc.ca/cise/
-----Original Message-----
From: Stefan Schwarzer [mailto:stefan.schwarzer at grid.unep.ch]
Sent: Thursday, February 26, 2004 2:42 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] SLD questions - How to filter
Dear list, dear Assefa,
I am trying to understand the functioning of the Styled Layer Descriptor and
am testing the 4.1 development version.
My "problem" (i.e. challenge) is the following: I would like to indicate a
country name within a WMS query, e.g. something like:
&WMTVER=1.0.0
&REQUEST=map
&TRANSPARENT=TRUE
&SRS=EPSG:4326
&BBOX=50,0,170,40
&WIDTH=300
&HEIGHT=150
&FORMAT=PNG
&layers=boundaries
&selectedCountry=China
in order to receive something like the attached map (highlighting the
selected country).
As far as I understand I have to setup a SLD file... (I am not at all sure
about the correct use of the parameters!)
<StyledLayerDescriptor version="1.0.0">
<NamedLayer>
<Name>boundaries</Name>
<UserStyle>
<Filter>
<PropertyIsEqualTo>
<PropertyName>[CNTRY_NAME]</PropertyName>
<Literal>Thailand</Literal>
</PropertyIsEqualTo>
</Filter>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
and attach it to the URL...
&SLD=PATH/sld.xml
My .map file (resp. the layer) is looking like this:
LAYER
NAME boundaries
TYPE POLYGON
STATUS ON
DATA boundaries
CLASSITEM CNTRY_NAME
LABELITEM CNTRY_NAME
CLASS
#EXPRESSION ('[CNTRY_NAME]' eq 'China')
NAME 'boundaries'
#OUTLINECOLOR 0 0 0
TEMPLATE 'dummy'
LABEL
FONT arial-bold
TYPE truetype
ANTIALIAS true
SIZE 12
COLOR 248 255 43
OUTLINECOLOR 0 0 0
END
END
END
But in the moment it doesn't work. Can anybody give me some hints or
indicate the location of some examples?
Thanks a lot,
Stefan
_______________________________________
Stefan Schwarzer
Consultant on GEO
UNEP/DEWA/GRID-Geneva
Chemin des Anemones 11
CH - 1219 Chatelaine
Switzerland
Tel: (+41) 22.917.83.49
Fax: (+41) 22.917.80.29
Email: stefan.schwarzer at grid.unep.ch
Internet: http://geodata.grid.unep.ch/
