[Mapserver-users] Empty Map with Oracle spatial - SDO_GTYPE
François-Xavier Prunayre fx.prunayre at oieau.fr
Thu Feb 26 10:16:51 EST 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0053_01C3FC83.F144A930
Content-Type: text/plain;
	charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi, if you are using OGR connection it works with SDO_GTYPE =3D 300x.=20
When you load shapefile or mapinfo tab using ogr2ogr in oracle spatial, it =
create 3D geom.
Try to add SRID information in your mapfile as Nicolas said previously ?=20
Francois
  ----- Original Message -----=20
  To: Henrik Wilsdorf ; mapserver-users at lists.gis.umn.edu=20
  Sent: Thursday, February 26, 2004 3:54 PM
  Subject: Re: [Mapserver-users] Empty Map with Oracle spatial
  Hi Henrik
      I don't know if I can  help you, but I will try.
      Did you import the data to OracleSpatial from shapefile? If yes, did =
you execute this command in sqlplus?    (EXECUTE SDO_MIGRATE.TO_CURRENT('TA=
BLE','GEOMETRY_COLUMN');
      If you execute your CGI passing layer=3Dpoints, what it happens? Can =
you see an image?
          http://willi1/scripts/mapserv.exe?map=3D/data/projects/spatial1/t=
estora1.map&mode=3Dmap&layers=3Dpoints
      Try to define one layer with status default and others with status of=
f , I don't know if import, just try.
      Well, look the SDO_GTYPE in your databate. It's report type 3003.  Th=
ree-dimensional polygon, I don't know if mapserv show this type. Try to pas=
s this type to 2003 .
  =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=20
  Fernando Simon - simon at cttmar.univali.br=20
  DataBase Manager, Mapserver, OracleSpatial and PostGis Developer=20
  G10 - Laborat=F3rio de Computa=E7=E3o Aplicada=20
  Fone: 047 - 341 7960=20
  http://g10.cttmar.univali.br
  Henrik Wilsdorf wrote:=20
Hi, Mapserver-users!
I'm trying to get a map from Oracle Spatial 9i (9.2), but only the shape
layer=20
is visible in the image but no data (no polygon, no line, no point) from
oracle.
With the shape layers all works fine in different maps.
No other errors occure, but one in MS_ERRORFILE:
    Thu Feb 26 12:26:40 2004 - msBuildPath: Unable to access file.
*** What does it mean???
 This error comes also, when I get a correct map without oracle layers.
The Oracle connection is also o.k.
When I have an error in the tablename I get the following text:
msDrawMap(): Image handling error. Failed to draw layer named 'polygons'.=
=20
msOracleSpatialLayerWhichShapes(): OracleSpatial error. ORA-00942: Tabelle
oder View nicht vorhanden .=20
SQL statement: SELECT rownum, GEOMETRY FROM POLYGONS1=20
WHERE SDO_FILTER( POLYGONS1.GEOMETRY,=20
MDSYS.SDO_GEOMETRY(2003, NULL, NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),
MDSYS.SDO_ORDINATE_ARRAY(-40,0,440,400) ),'querytype=3Dwindow') =3D 'TRUE'=
=20
With the corrected statement I got tho following data back in SQLplus:
ROWNUM GEOMETRY(SDO_GTYPE, SDO_SRID, SDO_POINT(X, Y, Z), SDO_ELEM_INFO,
SDO_ORDINATES)
     1 SDO_GEOMETRY(3003, NULL, NULL, SDO_ELEM_INFO_ARRAY(1, 1003, 1),
SDO_ORDINATE_ARRAY(50, 260, 0, 50, 90, 0, 120, 90, 0, 120, 260, 0, 50, 260,=
 0))
     2 SDO_GEOMETRY(3003, NULL, NULL, SDO_ELEM_INFO_ARRAY(1, 1003, 1),
SDO_ORDINATE_ARRAY(140, 80, 0, 340, 80, 0, 340, 150, 0, 140, 80, 0))
=20=20=20=20=20
This should be a rectangle and a triangle. Both are also shown in the Oracle
spatial advisor.
The spatial data are created with autodesk Map 2004.
I use Windows 2000 / IIS 5 and the binaries Mapserver 4.0.1 (PNG + Oracle)
from mapserver.gis.umn.edu.
The address I used in
IE6:
http://willi1/scripts/mapserv.exe?map=3D/data/projects/spatial1/testora1.ma=
p&mode=3Dmap
My Mapfile:
MAP
  NAME "testora1"
  STATUS ON
  EXTENT 0 0 400 400=20
  SIZE 600 500=20
  SHAPEPATH "data"
  SYMBOLSET "etc/symbols.sym"
  FONTSET "etc/fonts.txt"
  IMAGETYPE PNG
  IMAGECOLOR 255 255 200
  UNITS METERS
  WEB
    IMAGEPATH "/data/tmp/"
    IMAGEURL "/tmp/"
    LOG "/data/log/mslog.txt"
  END
=20=20
  LAYER
      NAME "polygonshape"
      STATUS DEFAULT
      DATA "polygonshape"
      TYPE POLYGON
      CLASS
        STYLE
          COLOR 200 200 100
          OUTLINECOLOR 1 1 1
         END
      END
  END
=20=20
  LAYER
        NAME "polygons"
        STATUS DEFAULT
        DATA "GEOMETRY FROM POLYGONS"
        TYPE POLYGON
        CONNECTIONTYPE ORACLESPATIAL
        CONNECTION "map1/abc at willi1"
        CLASS
          STYLE
            COLOR 0 128 128
            OUTLINECOLOR 1 1 1
          END
        END
    END
  LAYER
    NAME "polylines"
    STATUS DEFAULT
    DATA "GEOMETRY FROM POLYLINES"
    TYPE LINE
    CLASS
      STYLE
        COLOR 0 0 255
        SIZE 50
      END
    END
  END
=20=20
  LAYER
    NAME "points"
    STATUS DEFAULT
    DATA "GEOMETRY FROM POINTS"
    TYPE POINT
    CLASS
      STYLE
        SYMBOL 13
        COLOR 1 1 1
        SIZE 50
      END
    END
   END
=20=20=20
END
Waiting for some help.
Regards
Henrik Wilsdorf
=20=20
  --=20
  Ce message a ete verifie par MailScanner pour des virus ou des polluriels=
 et rien de suspect n'a ete trouve.=20
  Les donnees et renseignements contenus dans ce message sont personnels, c=
onfidentiels et secrets.Toute publication, utilisation ou diffusion, meme p=
artielle, doit etre autorisee.=20
  Any data and information contained in this electronic mail is personal, c=
onfidential and secret. Any total or partial publication, use or distributi=
on must be authorized.=20
--=20
Ce message a ete verifie par MailScanner pour des virus ou des polluriels e=
Les donnees et renseignements contenus dans ce message sont personnels, con=
fidentiels et secrets.Toute publication, utilisation ou diffusion, meme par=
Any data and information contained in this electronic mail is personal, con=
fidential and secret. Any total or partial publication, use or distribution=
 must be authorized.
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE></TITLE>
<META http-equiv=3DContent-Type content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Hi, if you are using OGR connection it wor=
ks with=20
SDO_GTYPE =3D 300x. </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>When you load shapefile or mapinfo tab usi=
ng=20
ogr2ogr in oracle spatial, it create 3D geom.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Try to add SRID information in your mapfil=
e as=20
Nicolas said previously&nbsp;? </FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Francois</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LE=
FT: #000000 2px solid; MARGIN-RIGHT: 0px">
  <DIV style=3D"FONT: 10pt arial">----- Original Message ----- </DIV>
  <DIV=20
  style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: black"><B>Fro=
m:</B>=20
  <A title=3Dsimon at inf.univali.br href=3D"mailto:simon at inf.univali.br">Fern=
ando=20
  S.</A> </DIV>
  <DIV style=3D"FONT: 10pt arial"><B>To:</B> <A title=3DH.Wilsdorf at gmx.net=
=20
  href=3D"mailto:H.Wilsdorf at gmx.net">Henrik Wilsdorf</A> ; <A=20
  title=3Dmapserver-users at lists.gis.umn.edu=20
  href=3D"mailto:mapserver-users at lists.gis.umn.edu">mapserver-users at lists.g=
is.umn.edu</A>=20
  </DIV>
  <DIV style=3D"FONT: 10pt arial"><B>Sent:</B> Thursday, February 26, 2004 =
3:54=20
  PM</DIV>
  <DIV style=3D"FONT: 10pt arial"><B>Subject:</B> Re: [Mapserver-users] Emp=
ty Map=20
  with Oracle spatial</DIV>
  <DIV><FONT face=3DArial size=3D2></FONT><FONT face=3DArial=20
  size=3D2></FONT><BR></DIV><FONT face=3D"Helvetica, Arial, sans-serif">Hi=
=20
  Henrik<BR>&nbsp;&nbsp;&nbsp; I don't know if I can&nbsp; help you, but I =
will=20
  try.<BR>&nbsp;&nbsp;&nbsp; Did you import the data to OracleSpatial from=
=20
  shapefile? If yes, did you execute this command in sqlplus?&nbsp;&nbsp;&n=
bsp;=20
  (EXECUTE=20
  SDO_MIGRATE.TO_CURRENT('TABLE','GEOMETRY_COLUMN');<BR>&nbsp;&nbsp;&nbsp; =
If=20
  you execute your CGI passing layer=3Dpoints, what it happens? Can you see=
 an=20
  image?<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; <A=20
  class=3Dmoz-txt-link-freetext=20
  href=3D"http://willi1/scripts/mapserv.exe?map=3D/data/projects/spatial1/t=
estora1.map&amp;mode=3Dmap&amp;layers=3Dpoints">http://willi1/scripts/mapse=
rv.exe?map=3D/data/projects/spatial1/testora1.map&amp;mode=3Dmap&amp;layers=
=3Dpoints</A><BR>&nbsp;&nbsp;&nbsp;=20
  Try to define one layer with status default and others with status off , =
I=20
  don't know if import, just try.<BR>&nbsp;&nbsp;&nbsp; Well, look the SDO_=
GTYPE=20
  in your databate. It's report type 3003.&nbsp; Three-dimensional polygon,=
 I=20
  don't know if mapserv show this type. Try to pass this type to 2003=20
  .<BR><BR>=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=20
  <BR>Fernando Simon - <A class=3Dmoz-txt-link-abbreviated=20
  href=3D"mailto:simon at cttmar.univali.br">simon at cttmar.univali.br</A>=20
  <BR>=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
  <BR>DataBase Manager, Mapserver, OracleSpatial and PostGis Developer <BR>=
G10 -=20
  Laborat=F3rio de Computa=E7=E3o Aplicada <BR>Fone: 047 - 341 7960 <BR><A=
=20
  href=3D"http://g10.cttmar.univali.br">http://g10.cttmar.univali.br</A><BR=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D</FONT>=20
  <BR><BR>Henrik Wilsdorf wrote:=20
  <BLOCKQUOTE cite=3Dmid12090.1077801762 at www38.gmx.net type=3D"cite"><PRE w=
rap=3D"">Hi, Mapserver-users!
layer=20
oracle.
=20
=20
SDO_ORDINATES)
 0))
=20=20=20=20=20
spatial advisor.
IE6:
<A class=3Dmoz-txt-link-freetext href=3D"http://willi1/scripts/mapserv.exe?=
map=3D/data/projects/spatial1/testora1.map&amp;mode=3Dmap">http://willi1/sc=
ripts/mapserv.exe?map=3D/data/projects/spatial1/testora1.map&amp;mode=3Dmap=
</A>
My Mapfile:
MAP
  NAME "testora1"
  STATUS ON
  SIZE 600 500=20
  SHAPEPATH "data"
  IMAGETYPE PNG
  UNITS METERS
  WEB
    IMAGEURL "/tmp/"
  END
=20=20
  LAYER
      NAME "polygonshape"
      STATUS DEFAULT
      DATA "polygonshape"
      TYPE POLYGON
      CLASS
        STYLE
          COLOR 200 200 100
          OUTLINECOLOR 1 1 1
         END
      END
  END
=20=20
  LAYER
        NAME "polygons"
        STATUS DEFAULT
        TYPE POLYGON
        CLASS
          STYLE
            COLOR 0 128 128
            OUTLINECOLOR 1 1 1
          END
        END
    END
  LAYER
    NAME "polylines"
    STATUS DEFAULT
    TYPE LINE
    CLASS
      STYLE
        COLOR 0 0 255
        SIZE 50
      END
    END
  END
=20=20
  LAYER
    NAME "points"
    STATUS DEFAULT
    TYPE POINT
    CLASS
      STYLE
        SYMBOL 13
        COLOR 1 1 1
        SIZE 50
      END
    END
   END
=20=20=20
END
Regards
Henrik Wilsdorf
  </PRE></BLOCKQUOTE><BR><BR>-- <BR>Ce message a ete verifie par <A=20
  href=3D"http://www.mailscanner.info/"><B>MailScanner</B></A> pour des vir=
us ou=20
  des polluriels et rien de suspect n'a ete trouve.=20
  <DIV><FONT face=3D3DArial size=3D3></FONT>&nbsp;</DIV>Les donnees et=20
  renseignements contenus dans ce message sont personnels, confidentiels et=
=20
  secrets.Toute publication, utilisation ou diffusion, meme partielle, doit=
 etre=20
  autorisee.=20
  <DIV><FONT face=3D3DArial size=3D3></FONT>&nbsp;</DIV>Any data and inform=
ation=20
  contained in this electronic mail is personal, confidential and secret. A=
ny=20
  total or partial publication, use or distribution must be authorized.=20
</BLOCKQUOTE></BODY><br />--=20
<br />Ce message a ete verifie par <a href=3D"http://www.mailscanner.info/"=
><b>MailScanner</b></a>
pour des virus ou des polluriels et rien de suspect n'a ete trouve.
<DIV><FONT face=3D3DArial size=3D3D2></FONT>&nbsp;</DIV>
 must be authorized.
</HTML>
------=_NextPart_000_0053_01C3FC83.F144A930--
