[Mapserver-users] Mapscript doesn't write map file in expected
order!
Vladimir Guzmán
bigfoot at main-task.com
Thu Feb 26 20:45:24 EST 2004
Maybe you should write the mapfile with your own php's function. No?
Vladimir Ilich Guzmán R.
http://www.maintask.com
Xiaoyuan Geng wrote:
>Hello
>I am using PHP Mapscript to add more METADATA contents to a map file.
>It seems that Mapscript resorts the contents of METADATA members before
>I same the map file. Also mapscript adds tab instead of one space
>between the name and the content. Any way to fix this problem? Below is
>the example:
>Expected order:
> $myMap->setMetaData("wms_title", "GDAS Geolinking
>Map");
> $myMap->setMetaData("wfs_title", "GDAS Geolinking Map");
> $myMap->setMetaData( "wms_onlineresource",$strWMS_WFS );
> $myMap->setMetaData( "wfs_onlineresource",$strWMS_WFS
> $myMap->setMetaData( "wms_srs",SERVER_PROJECTIONS );
> $myMap->setMetaData( "wfs_srs",SERVER_PROJECTIONS );
> $myMap->setMetaData( "wms_feature_info_mime_type","text/html"
>Mapscript output:
> "wms_srs" "EPSG:4269 EPSG:42304 EPSG:42101 EPSG:4326
>EPSG:26907"
> "wms_onlineresource" "myserver/cgi-bin/mapserv?map=map file
>name"
> "wms_title" "GDAS Geolinking Map"
> "wms_feature_info_mime_type" "text/html"
> "wfs_srs" "EPSG:4269 EPSG:42304 EPSG:42101 EPSG:4326
>EPSG:26907"
> "wfs_title" "AAFC GDAS Geolinking Map"
> "wfs_onlineresource" "myserver/cgi-bin/mapserv?map=map file
>name"
>Thank you very much!
>Shawn
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
