[Mapserver-users] Error in TIGER to shp conversion !!!!
Dharani Babu
dharanibabus at hotmail.com
Fri Feb 27 05:46:47 EST 2004
Hi all
I am trying to render TIGER files with mapserver . I am using
CONNECTIONTYPE OGR and got the CompleteChain , Landmarks , PIP displayed of
TGR33015 file(s) . But as I am not able to get the names of locations
displayed I tried to convert the tiger files into shp files .
I tried this way
c:/>openev>ogr2ogr -f "ESRI Shapefiles" shp
"c:/ms4w/apache/htdocs/demof/data/rm"
here shp is the folder I want the translated shape files to be in . But I
got the errors
Error 6: Can't Create fields of type IntegerList on shapefil layers
Error 1 : Attempt to write feature without geometry not supported for
shapefile driver
Error 1 : terminating translation prematurely after failed translation of
layer Landmarks
I checked the /shp folder and found that the following files are in ..
CompleteChain(.shp,.shx,.prj,.dbf)
AltNames(.dbf,.prj)
FeatureIds(.dbf,.prj)
Landmarks(.shp,.shx,.prj,.dbf)
ZipCodes(.dbf,.prj)
It seems only above mentioned layers are converted into shp files . I found
the total list of layers avble from ogrinfo<tigerfolder>
1: CompleteChain (Line String)
2: AltName (None)
3: FeatureIds (None)
4: ZipCodes (None)
5: Landmarks (Point)
6: AreaLandmarks (None)
7: KeyFeatures (None)
8: Polygon (None)
9: EntityNames (Point)
10: IDHistory (None)
11: PolyChainLink (None)
12: PIP (Point)
13: TLIDRange (None)
14: ZipPlus4 (None)
So how to get all these layers translated ? or is it the default behavior of
ogr2ogr when it comes to TIGER translations ? Could any of you help me
understand this ?
with regards and thanks
dharani babu
_________________________________________________________________
Post Classifieds on MSN classifieds. http://www.sulekha.com/msnclassifieds
Buy and Sell on MSN Classifieds.
