[Mapserver-users] listing field names of my $oShape->values;
(Because it's Friday???)
Dylan Keon
keon at nacse.org
Fri Feb 27 16:53:36 EST 2004
Denis,
$oShape->values is an associative array. Asking for $flds[$fieldcount]
will give you nothing since the keys are not a numeric index.
Try replacing your "for" loop with this:
foreach($oShape->values as $key=>$value) {
echo "$key = $value<br>\n";
Just echo $key to get the field names only.
--Dylan
FX Gamoy wrote:
> hello
> try
> print_r($oShape);
> or
> print_r($oShape->values);
> fx gamoy
> http://www.mapxplore.com/
> ----- Original Message -----
> *From:* Denis Lalonde <mailto:denlalonde at yahoo.com>
> *To:* mapserver-users at lists.gis.umn.edu
> <mailto:mapserver-users at lists.gis.umn.edu>
> *Sent:* Friday, February 27, 2004 9:34 PM
> *Subject:* [Mapserver-users] listing field names of my
> $oShape->values; (Because it's Friday???)
> Hello all,
> I'm simply trying to get a list of the field names of a layer...
> I'm using php & mapscipt 4 and accessing my MapInfo data (OGR)
> Here's my code that's not working (I get "Undefined offset" error
> when accessing the array):
> I have my results and my layer set; the result of my echo
> sizeof($flds) is 20 which is good. The item that I am querying does
> have data in all 20 fields.
> $oRes = $oLayer->getResult($iRes);
> $oShape = $oLayer->getShape(-1,$oRes->shapeindex);
> $flds=$oShape->values;
> echo "numfields: ".sizeof($flds)."<br>";
> for ($fieldcount=0; $fieldcount < sizeof($flds);
> $fieldcount++)
> echo $flds[$fieldcount];
> should that not spit me out my field names?
