[Mapserver-users] Mapserver compiled and source download
mountainduo at mho.com
Sun Feb 29 18:58:50 EST 2004
I guess what i hoped to get is a download file that had the source and
also the compiled objects so then i can create a windows dll so i can use
java.
i get the mapscript_wrap.c to compile but then when i try to link the
compiled object i get a lot of undifined references to mapserver
functions. This is where i need the compiled mapserver library files so i
can link and create my dll. I had thought i had seen somewhere that there
was a mapserver.lib file but i could be wrong.
can you post this zip file?
thanks a lot
> mapserver.lib ???
> I never saw it before! please be sure the filename u want.
> best.
> Eduardo Patto Kanegae
> http://www.consultoria.eti.br
> ## Projeto MapServer Brasil - http://mapserver.cttmar.univali.br ##
> ***Fim da Mensagem / End of Message ***
> On Sat, 28 Feb 2004 15:23:30 -0700 (MST), <mountainduo at mho.com>
> escreveu:
>> De: <mountainduo at mho.com>
>> Data: Sat, 28 Feb 2004 15:23:30 -0700 (MST)
>> Para: <eduardo at consultoria.eti.br>
>> Assunto: Re: [Mapserver-users] Mapserver compiled and source download
>> Thank you for your reply. I have downloaded a few of the files but
>> still can't find the mapserver.lib file. Can you tell me which file i
>> should download?
>> thanks again,
>> will
>> > http://www2.dmsolutions.ca/webtools/dl/
>> > On Sat, 28 Feb 2004 13:41:30 -0700 (MST), <mountainduo at mho.com>
>> escreveu:
>> >> Data: Sat, 28 Feb 2004 13:41:30 -0700 (MST)
>> >> Para: <mapserver-users at lists.gis.umn.edu>
>> >> Assunto: [Mapserver-users] Mapserver compiled and source download
>> >> Hello,
>> >> Is there somewhere where i can download the source and compiled
>> version together? I am having problems compiling mapserver and all
>> i really need is the mapserver.lib file (and any other library
>> files).
>> >> thank you for your help,
>> >> will
>> >> _______________________________________________
>> >> Mapserver-users mailing list
>> >> Mapserver-users at lists.gis.umn.edu
>> >> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
