[Mapserver-users] Reference map to show boundingcoordinates extent not map extent
John.Hockaday at ga.gov.au
Sun Feb 29 22:36:16 EST 2004
Steve,
Thanks for this information. I have finally got around to implementing your
suggestions. (I've had lots of fires to put out.) ;--)
I have created what I think should work at the following URL:
http://asdd.ga.gov.au/asdd/reference_call.html
I've tried combinations inside my map file:
http://asdd.ga.gov.au/asdd/ref.map
I've looked at your tomo code and tried adding and removing different symbols
but I still keep on getting this following error:
"getDouble(): Symbol definition error. (+):(51)"
It seems that I'm missing something in my map file but for the life of me I
can't work out what it is.
I'd appreciate any help that you or someone else on this list can provide to
fix my problem.
Thanks.
John
> -----Original Message-----
> From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
> Sent: Thursday, 5 February 2004 5:05
> To: Hockaday John; mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Reference map to show
> You can build your reference maps just as a regular map. I've
> done that
> before. In fact you used to have to if you wanted to do things like
> change the representation of the extent based on scale.
> The idea goes like this. In a new mapfile
> 1) set the main EXTENT to whatever your reference image is
> 2) set the size to match the reference image
> 3) add the reference image as a raster layer, make sure to
> set TRANSFORM
> FALSE (this effectively pastes the image in the map)
> 4) create a layer to draw the extent with, the coordinates will be
> supplied dynamically, this might work
> LAYER
> NAME 'box'
> TYPE POLYGON
> STATUS OFF
> CLASS COLOR 255 0 0 END
> END
> 5) now, in your template make a call to the mapfile, something like:
> http://.../cgi-bin/mapserv?mode=map&map=reference.map&layer=box
> &map_box_feature=new&map_box_feature_points=[rawminx]+[rawminy
> ]+[rawminx]+[rawmaxy]+...
> Basically you do exactly what MapServer does internally in
> the reference
> map functions, but you force feed it the rectangle of your choice
> dynamically. The reference map on this page is built using this
> approach:
> http://www.dnr.state.mn.us/maps/tomo.html
> Hope this helps!
> Steve
> >>> <John.Hockaday at ga.gov.au> 02/04/04 11:10 PM >>>
> Hi all,
> I am using cgi mapserv to identify a bounding box which is used to
> define a
> region in another application. I use JavaScript to allow the user to
> drag a
> bounding box on the [img] and the resulting [rawminx], [rawminy] etc.
> coordinates are sent to mapserv which returns an image zoomed into the
> selected region. The image size is fixed so there is some area either
> above
> and below or to the left and right of the selected region which is
> outside of
> the area defined by the user.
> Mapserv also returns a reference map and the defined area on that map
> shows
> the extent of the mapserv image but not the extent of the
> region defined
> by
> the user.
> Are there some parameters that can be sent to a cgi mapserv
> so that the
> reference map indicates the [rawminx], [rawminy], [rawmaxx] and
> [rawmaxy]
> converted to lats and long instead of the [imgext]? Or is there some
> other
> way of creating a reference map with the [imgbox] coordinates and not
> the
> [imgext] coordinates?
> Thanks.
> John
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
