[Mapserver-users] mapscript - strange behavior
Christoph Spoerri
spoerri at duke.edu
Tue Jan 13 17:30:31 EST 2004
Yes, I'm using mod_python but don't use a persistent mapObj (I assume you mean
storing the object as session variable). I tried it, but it lead only to seg.
faults.
The reason for not using a predefined acetate layers is how my app is coded. I
didn't want to change things around, and since the problem looks like a bug,
and I was wondering if there's a solution. Also, I wasn't sure if I'm doing
something wrong.
Christoph
On Tuesday 13 January 2004 02:28 pm, Sean Gillies wrote:
> On Jan 13, 2004, at 10:38 AM, Christoph Spoerri wrote:
> > Hi there,
> > I'm writing an application that let's user add point features to the
> > map by
> > clicking on any location of the map. For this purpose I'm using the
> > attached
> > code (Note: each click on the map results in a request to the server
> > for a
> > new image).
> > The problem is that the first point (to be mapped) is not displayed on
> > the
> > map. Yet when the user clicks on the map for the second time (to add a
> > new
> > point) both points show up. When checking the .map files everything
> > looks
> > fine: acetate layer is there, class definition looks fine and point
> > coordinates are there.
> > In case a predefine the acetate layer (w/ class def) in the base .map
> > file,
> > the first point shows up just fine. Note: this solution is not an
> > option
> > thought :(
> > any ideas? Thanks in advance,
> > Christoph
> > *********** code ********************
> > x = atof(param['x'])
> > y = atof(param['y'])
> > # create point object
> > ptCoord = getMapPoint([x,y],self._map)
> > ptObj = pointObj()
> > ptObj.x=ptCoord[0]
> > ptObj.y=ptCoord[1]
> > lnObj = lineObj()
> > lnObj.add(ptObj)
> > # create new point layer with class and add shape
> > mapImg=self._map.prepareImage()
> > lyrAcetate = self._map.getLayerByName('acetate')
> > if (not isinstance(lyrAcetate,layerObj)):
> > color = colorObj()
> > color.red = 255
> > color.green = 255
> > color.blue = 255
> > lyrAcetate = layerObj(self._map)
> > lyrAcetate.name = "acetate"
> > lyrAcetate.type = MS_LAYER_POINT
> > classTemp = classObj(lyrAcetate)
> > styl = styleObj()
> > styl.symbolname = "pin"
> > styl.size = 1
> > styl.maxsize = 1
> > styl.minsize = 1
> > styl.color = color
> > styl.backgroundcolor = color
> > styl.outlinecolor = color
> > classTemp.numstyles=1
> > classTemp.styles = styl
> > # create shape object and add point to shape object
> > shpObj = shapeObj(MS_SHAPE_POINT)
> > shpObj.add(lnObj)
> > shpObj.setBounds();
> > shpObj.index = 1
> > lyrAcetate.status = MS_ON
> > lyrAcetate.addFeature(shpObj)
> > lyrAcetate.draw(self._map,mapImg)
> > imagename = \
> > self._map.name+mapSession.id()+"_"+str(int(time()))+"."+mapImg.format.e
> > xtension
> > mapImg.save(mapImg.imagepath+imagename)
> Christoph,
> Do I remember correctly that you are using mod_python? Is this a reason
> why you say that you cannot predefine your acetate layer? I hope you
> are
> not trying to persist a mapObj in the same way that mod_python users use
> persistent database connections. MapServer is not fully thread-safe
> (yet)
> and so you will certainly encounter some trouble with a persistent
> mapObj.
> I don't see _anything_ in your code that would prevent the acetate layer
> from being predefined in your map file. If it is only a matter of
> colors and styles, I strongly recommend that you predefine the acetate
> layer and then modify its classes and styles during the script
> execution.
> cheers,
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://users.frii.com/sgillies
