[Mapserver-users] Error when querying PostGIS layer
Dylan Keon
keon at nacse.org
Thu Jan 15 15:01:11 EST 2004
I'd be really grateful if some of you postgis/postgres gurus could give
me a hand with this (see question below) - it's got me stumped. Jason
Nielsen posted a similar question a little while ago.
I've already tried GRANT SELECT ON quad24k TO PUBLIC; and verified that
the asbinary SELECT statement following 'DECLARE mycursor BINARY CURSOR
FOR' works in psql.
TIA for any help. I pasted some more info at the bottom of the message.
--Dylan
Dylan Keon wrote:
> I'm having trouble querying a PostGIS layer via PHP Mapscript. The
> layer renders fine in the app and labels get generated, etc. But I get
> an error when trying to query the layer. It fails when it reaches
> getShape() - if I comment out that line everything else works. Also, if
> I run this code on a shapefile version of the same layer it works fine.
> I'm using MS 4.0.1, Postgres 7.4.1, PostGIS 0.8.1 on Linux. Thanks for
> any help.
> --Dylan
> From the apache error log:
> PHP Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named
> 'quad_index_24k'.
> in /opt/httpd/htdocs/test.php on line 132
> PHP Warning: [MapServer Error]: prep_DB(): Error executing POSTGIS
> DECLARE (the actual query) statement: 'DECLARE mycursor BINARY CURSOR
> FOR SELECT
> nf1::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text
> from quad24k WHERE the_geom && setSRID('BOX3D(311625 301705,586625
> 577205)'::BOX3D, find_srid('','quad24k','the_geom') )' <br><br>
> Postgresql reports the error ''<br><br>
> More Help:<br><br>
> Error with POSTGIS data variable. You specified '<check your .map
> file>'.<br>
> Standard ways of specifiying are : <br>
> (1) 'geometry_column from geometry_table' <br>
> (2) 'geometry_column from (<sub query>) as foo using unique
> <column name> using SRID=<srid#>' <br><br>
> Make sure you put in the 'using unique <column name>' and 'using
> SRID=#' clauses in.
> <br><br>For more help, please see
> http://postgis.refractions.net/documentation.php
> <br><br>Mappostgis.c - version of June 12/2003.
> PHP Fatal error: Call to a member function on a non-object in
> /opt/httpd/htdocs/test.php on line 133
> // simple function for testing postgis layer query
> function doQuery($map, $map_x, $map_y, $last_extent)
> $layer = $map->getLayerByName('quad_index_24k');
> $coords = pix2geo($map, $map_x, $map_y, $last_extent);
> $geo = preg_split("/,/", $coords);
> // create point object
> $click_pt = ms_newPointObj();
> $click_pt->setXY($geo[0], $geo[1]);
> // query the map at the point clicked
> @$map->queryByPoint($click_pt, MS_SINGLE, -1);
> $count_results = $layer->getNumResults();
> echo "count_results = $count_results<br>\n";
> if($count_results > 0) {
> $layer->open();
> $result = $layer->getResult(0);
> echo "<pre>getResult:<br>"; print_r($result); ech "</pre>";
> $resultShape = $layer->getShape(-1,$result->shapeindex);
> echo "<pre>getShape:<br>"; print_r($resultShape); echo "</pre>";
> } else echo "No records returned";
> $click_pt->free();
> $resultShape->free();
> LAYER
> NAME quad_index_24k
> TYPE POLYGON
> CONNECTIONTYPE POSTGIS
> CONNECTION "user=read dbname=oregon"
> DATA "the_geom from quad24k"
> STATUS ON
> MAXSCALE 2400000
> LABELMAXSCALE 600000
> LABELMINSCALE 20000
> TEMPLATE "null"
> CLASS
> OUTLINECOLOR 0 25 140
> COLOR -1 -1 -1
> COLOR 190 230 190
> TEXT ([name] [nf1])
> LABEL
> WRAP " "
> POSITION CC
> SIZE SMALL
> BUFFER 50
> FORCE TRUE
> MINFEATURESIZE 35
> END
> END
> END
Here are some additional data:
oregon=# select * from geometry_columns where f_table_name = 'quad24k';
f_table_catalog | f_table_schema | f_table_name | f_geometry_column |
coord_dimension | srid | type | attrelid | varattnum | stats
| public | quad24k | the_geom |
2 | -1 | MULTIPOLYGON | 17407 |
19 |
(1 row)
oregon-# \d quad24k
Table "public.quad24k"
Column | Type | Modifiers
gid | integer |
area | double precision |
perimeter | double precision |
id | bigint |
name | character varying |
states | character varying |
latlon | character varying |
usgscode | character varying |
scale | character varying |
ohiocode | character varying |
st_s | integer |
st_w | integer |
the_geom | geometry |
usfscode | character varying(7) |
nf1 | character varying(3) |
nf2 | character varying(3) |
nf3 | character varying(3) |
geoloc | character varying(4) |
Indexes:
"quad24k_gist" gist (the_geom)
"quad24k_oid" btree (oid)
