[Mapserver-users] wms server projection
Markus Schnider
sp_ml at sourcepole.com
Thu Jul 1 03:48:14 EDT 2004
Hi all
I have a umn mapserver 4.2 wms-server and chameleon.
I would include a layer of this wms server. The projection of the layer has an
alpha value of 90 (init=epsg:21781), which produces an error.
<21781> +proj=omerc +lat_0=46.95240555555556 +lonc=7.439583333333333 +alpha=90
+k=1 +x_0=600000 +y_0=200000 +ellps=bessel +units=m +no_defs no_defs <>
so I would change the alpha value to 89, but how can I include the projection
in the mapfile withaout an entry like
"init=epsg:21781"
Is it possible to create my own projection in the web part of the mapfile?
Should I create an own file with my own projection like a 'epsg', 'esri', ...
file (the server and the client could then use the same projection file)?
Which is the best way?
Thanks in advance
Markus Schnider
PS: Chameleon or the wms-server works at this time only if the alpha value is
different of 90. So I changed the projection to this values.
