[Mapserver-users] can't view 2 WMS layers(from 2 different servers)
Eduardo Patto Kanegae
eduardo at consultoria.eti.br
Fri Jul 2 08:50:25 EDT 2004
After adding the 1st server ( "Teste1") , it logged:
07/02/04 09:48:13 Sending Request to server GET
http://localhost/cgi-bin/mapserv.exe?map=C:/local/web/testewms/wms1.map&&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=estados&SRS=EPSG:4291&BBOX=-73.991,-33.751,-32.378,5.27222&WIDTH=545&HEIGHT=511&FORMAT=image/gif&STYLES=&TRANSPARENT=FALSE
and after adding the 2st server ( "Teste2") , got:
07/02/04 09:50:30 Sending Request to server GET
http://localhost/cgi-bin/mapserv.exe?map=C:/local/web/testewms/wms2.map&&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=sedes&SRS=EPSG:4291&BBOX=-53.2885325,-14.3370575,-53.0804675,-14.1419425&WIDTH=794&HEIGHT=563&FORMAT=image/gif&STYLES=&TRANSPARENT=FALSE
why is it requesting GIF instead PNG, and TRANSPARENT FALSE instead TRUE?
best.
Eduardo
bartvde at xs4all.nl escreveu:
>Hi,
>Can you check which format ArcGIS is requesting, e.g. by logging the
>GetMap URL? Maybe it is requesting the images in jpeg?
>Best regards,
>Bart
>>Hi,
>>I set up two WMS mapfile server and installed Intereoperability Tools
>>for ArcGIS 8.x but I can't view the both layers together in ArcGIS ( one
>>over the other - one is a point layer and the other is polygon layer).
>>Here's the first mapfile:
>>1 --------------
>>MAP
>> NAME "wmsserver"
>> EXTENT -73.991 -33.751 -32.378 5.272
>> SHAPEPATH "C:/local/mapas/mapasBrasil/"
>> SIZE 600 400
>> IMAGECOLOR -1 -1 -1
>> IMAGETYPE PNG
>> OUTPUTFORMAT
>> NAME PNG
>> DRIVER "GD/PNG"
>> MIMETYPE "image/png"
>> IMAGEMODE PC256
>> EXTENSION "png"
>> TRANSPARENT ON
>> END
>> PROJECTION
>> "init=epsg:4291"
>> END
>> WEB
>> METADATA
>> "wms_title" "Teste1"
>> "wms_onlineresource"
>>"http://localhost/cgi-bin/mapserv.exe?map=C:/local/web/testewms/wms1.map&"
>> "wms_srs" "EPSG:4291"
>> END
>> END
>>LAYER
>> NAME "estados"
>> PROJECTION
>> "init=epsg:4291"
>> END
>> METADATA
>> "wms_title" "Estados"
>> "wms_group_title" "Todos"
>> END
>> TRANSPARENCY 50
>> TYPE POLYGON
>> DATA "br_uf"
>> CLASS
>> COLOR 128 128 192
>> OUTLINECOLOR 0
>> END
>> DUMP TRUE
>>END
>>END
>>and here's the 2nd one:
>>2-----------
>>MAP
>> NAME "wmsserver"
>> SIZE 600 400
>> IMAGECOLOR -1 -1 -1
>> IMAGETYPE PNG
>> OUTPUTFORMAT
>> NAME PNG
>> DRIVER "GD/PNG"
>> IMAGEMODE PC256
>> EXTENSION "png"
>> TRANSPARENT ON
>> END
>> PROJECTION
>> "init=epsg:4291"
>> END
>> WEB
>> METADATA
>> "wms_title" "Teste2"
>>"http://localhost/cgi-bin/mapserv.exe?map=C:/local/web/testewms/wms2.map&"
>> END
>> END
>>SYMBOL
>> NAME 'ponto'
>> TYPE ELLIPSE
>> FILLED TRUE
>> POINTS
>> 1 1
>> END
>>END
>>LAYER
>> DUMP TRUE
>> NAME "sedes"
>> PROJECTION
>> "init=epsg:4291"
>> END
>> METADATA
>> "wms_title" "Sedes"
>> END
>> TYPE POINT
>> DATA "br_sede"
>> TRANSPARENCY 50
>> CLASS
>> COLOR 255 0
>> OUTLINECOLOR 255 0
>> SYMBOL "ponto"
>> SIZE 2
>> END
>>END
>>END
>>in ArcGIS when I load
>>and
>>connection I can't view one over the other. only top layer appears.
>>what is wrong?
>>http://www.consultoria.eti.br
>>UIN: 303747254
>>Treinamento em UMN MapServer -
>>http://www.consultoria.eti.br/ptbr/?menuoption=mapserver
>>I Encontro Nacional de Usuários MapServer -
>>http://mapserver.cttmar.univali.br/encontro2004
>>Fórum MapServer Brasil - http://mapserver.cttmar.univali.br/forum
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
UIN: 303747254
Treinamento em UMN MapServer - http://www.consultoria.eti.br/ptbr/?menuoption=mapserver
I Encontro Nacional de Usuários MapServer - http://mapserver.cttmar.univali.br/encontro2004
***Fim da Mensagem / End of Message ***
