[Mapserver-users] Join Query error
Steve Lime
steve.lime at dnr.state.mn.us
Fri Jul 2 17:01:19 EDT 2004
Hi Rich: Joins live by themselves inside layers. Query objects are long
gone. Here's an
example for a one-to-one join with a csv file. In the case of a
one-to-many join you'd
have a template defined in the join.
# 1 by 1/2 Degree (100K) Quadrangle Index
LAYER
NAME "L210000030201"
STATUS OFF
TYPE QUERY
# data access information
DATA "/r01/data/drs/metadata/mapserver/gen_state"
FILTERITEM "C210030201"
FILTER /./
# result presentation information
TEMPLATE "query_result.html"
HEADER "query_layer_header.html"
FOOTER "query_layer_footer.html"
JOIN
NAME "stats"
CONNECTIONTYPE CSV
TABLE
"/r01/data/drs/metadata/data_def/layer_stat/indx_q100kpy4_stat.txt"
FROM "TILE_ID"
TO "1"
END
END
Steve
>>> Richard Greenwood <rich at greenwoodmap.com> 7/2/2004 1:43:38 PM >>>
I'm struggling with a join, type multiple. First off I get:
loadLayer(): Unknown identifier. Parsing error near (QUERY):(line
428)
(see map file below). If I comment out the QUERY and corresponding END,
I get rid of the error, but still no data from the joined dbf. The data
from the base table is displayed, but then "[CATS]" is displayed rather
than the cat.html template.
Seems like maybe I shouldn't have a CLASS in a layer with a QUERY, but
removing it doesn't really effect things much.
Can anybody point me to a working example that I could examine?
Thanks,
Rich
=== map file ====
LAYER
NAME "ownership"
STATUS ON
TYPE POLYGON
DATA "ownership"
HEADER "attribute_header.html"
FOOTER "attribute_footer.html"
QUERY
JOIN
NAME CATS
TABLE "/fc/data/cat.dbf"
FROM DESCRIPTOR
TO CAPKEY
TYPE multiple
TEMPLATE cat.html
END # of JOIN Object
END # of query
CLASS
Name "Lot and Parcel Lines"
TEMPLATE "attribute_display.html"
SYMBOL "Solid"
OUTLINECOLOR 0 0 0
SIZE 2
END # class
END # layer
=== attribute_display.html ====
<li>Name : [NAME]</li>
<li>Mailing Address : [ADDRESS1]</li>
<li>Mailing Address : [ADDRESS2]</li>
<li>Mailing Address : [CITY], [STATE] [ZIPCODE]</li>
<li>Street Address : [ST_NUM1] [ST_NUM1_2] [ST_DIR_PRE] [ST_NAME]
[ST_DIR_SUF]</li>
<li>Descript : [DESCRIPT]</li>
<li>Area_tax : [ACRES_TAX]</li>
<li>Area_calc : [AREA]</li>
<li>Code Area : [CODE_AREA]</li><BR>
[CATS]
=== cat.html ===
<li>Category : [Cacat] [Descript]</li>
Richard Greenwood
www.greenwoodmap.com
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
