[Mapserver-users] msDrawMap() error
Oliver Ishmael
oliver_ishmael at hotmail.com
Sun Jul 4 07:09:23 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_43f2_686_51b8
Content-Type: text/plain; format=flowed
Hi all,
i am still trying to write my first .map file but have run into the
following errors:
msDrawMap(): Image handling error. Failed to draw layer named 'luzon'.
msSHPOpenFile(): Unable to access file.
(C:\library\sites\mapserver\projects\testing\admin)
(C:\library\sites\mapserver\projects\testing\mapserver/admin)
I have attached a copy of my .map file and hope that someone can offer a
little help. As always any help greatly appreciated.
Cheers
Oliver Ishmael
_________________________________________________________________
Stay in touch with absent friends - get MSN Messenger
http://www.msn.co.uk/messenger
Content-Type: text/plain; name="luzon_test.map"; format=flowed
Content-Transfer-Encoding: 8bit
Content-Disposition: attachment; filename="luzon_test.map"
MAP
# OUTPUTFORMAT
# # this may automatically be called from a library of sorts...not yet sure!
# NAME png
# DRIVER "GD/PNG"
# MIMETYPE "image/png"
# IMAGEMODE PC256
# EXTENSION "png"
# END
NAME LUZON_TEST
IMAGETYPE PNG
EXTENT 115.8 10.99 127.8 19.15
SIZE 600 400
SHAPEPATH "mapserver"
# need to find an index of colours...
IMAGECOLOR 255 255 255
PROJECTION
# this code can be found in the "epsg.file" (when opened in txt ed. it
lists every projection
# and their respective epsg codes)
"init=epsg:4252"
# for some reason this projection is usually dif from the layer
projection...why?!
END
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER # Luzon Island polygon layer begins here
NAME luzon
DATA admin
STATUS DEFAULT
TYPE POLYGON
PROJECTION
# this is the exact code for Luzon using UTM
"init=epsg:4252"
END
CLASS
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END # States polygon layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # end of map file/object
# MAKE SURE TO 'SAVE AS' TO THE ADDRESS BELOW WHEN MAKING CHANGES!
# THIS IS REALLY IT!
#http://localhost/cgi-bin/mapserv.exe?map=C:\library\sites\mapserver\projects\testing\luzon_test.map&mode=map
#GOT THIS ERROR THOUGH!
# msCalculateScale(): General error message. Invalid image extent.
# mapserv(): Web application error. No way to generate map extent.
------=_NextPart_000_43f2_686_51b8--
