[Mapserver-users] Building MapServer for Max OS X (10.3)
Ken-ichi Ueda
kueda at wso.williams.edu
Tue Jul 6 23:06:34 EDT 2004
I got MS up and running on my PowerBook a month or two ago, mostly
using the directions you've found (which are great). My only qualm is
that I highly advise avoiding Fink altogether. I'm a relative *nix
newbie, so I tried to use Fink as much as possible, but Fink often
didn't have versions of the dependancies that worked with MS, and even
when the right versions were available, they often didn't work, even
when referred to explicitly when calling the ./configure script.
Compiling and installing everything by hand seemed like the most
reliable way of getting everything to work. Also, if you're going to
use PHP MapScript, make sure you compile PHP against the same libraries
you used for MapServer, or things could get ugly.
-Ken-ichi
On Jul 6, 2004, at 6:28 PM, Bill Stephenson wrote:
> Hi all,
> I'm going to be trying to build MapServer on a Mac OS X (10.3) box and
> found these instructions (for 10.2) after searching the list:
> http://home.nc.rr.com/wwheaton/
> I'm going to try and build this with the latest stable releases of the
> libraries mentioned in the instructions above but I'm wondering if
> anyone here might have done this already on 10.3 and if they might
> offer any suggestions?
> Thanks,
> Bill Stephenson
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
