[Mapserver-users] Place of an image in the web page
Tony Jolibois tjolibois at cls.fr
Wed Jul 7 11:01:02 EDT 2004
This is a multi-part message in MIME format.
--------------020106090403090101090809
Content-Type: multipart/alternative;
 boundary="------------090405080304070304050505"
--------------090405080304070304050505
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 8bit
          Hi all,
I'm a little new to mapserver.
I try to plot a layer with mapserver but I think I'm wrong with the
imagexy or something with  the place of the image.
The layer comes from an Opendap data (raster data read by GDAL). The
image attached has been product with "shp2img -m example3.map -o
/data/out3.png".
So the map file look good, but when I try to put it in a web page with
mapserver, the image is not at the center of the page, and is "returned".
Someone has an idea about it ?
Thanks in advance,
Tony Jolibois
The map file I use for the mapserver :
MAP
  NAME           EX2.1_
  IMAGETYPE      png
  EXTENT         0 -80 360 80
  SIZE           1000 500
  SHAPEPATH      "/var/www/html/tutorial/data"
  SYMBOLSET      "symbols/symbols35.sym"
  FONTSET        "fonts/fonts.list"
  IMAGECOLOR     0 0 0
  WEB
    TEMPLATE  'example-cls.html'
    IMAGEPATH '/var/www/html/tutorial/data/tmp/'
    IMAGEURL  '/tmp/'
  END
CONFIG DODS_BLOCK_ORIENTED "1"
CONFIG DODS_AIS_FILE "ocean_ais3.xml"
LAYER
  NAME grid1
  TYPE raster
  STATUS default
  DATA
'http://opendap.aviso.oceanobs.com/dodsC/merged/h/msla_oer_merged_h?Grid_0001[0][lon][lat]'
  PROCESSING "SCALE=-100,1000"
  CLASS
    NAME "(< -50cm)"
    EXPRESSION ([pixel] < -50)
    COLOR 238 5 254
  END
  CLASS
    NAME "(-50 -40)"
    EXPRESSION ([pixel] < -40)
    COLOR 150 5 254
  END
  CLASS
    NAME "(-40 -30)"
    EXPRESSION ([pixel] < -30)
    COLOR 50 5 254
  END
  CLASS
    NAME "(-30 -20)"
    EXPRESSION ([pixel] < -20)
    COLOR 6 64 254
  END
  CLASS
    NAME "(-20 -10)"
    EXPRESSION ([pixel] < -10)
    COLOR 6 159 254
  END
  CLASS
    NAME "(-10 0)"
    EXPRESSION ([pixel] < 0)
    COLOR 7 254 240
  END
  CLASS
    NAME "(0 10)"
    EXPRESSION ([pixel] < 10)
    COLOR 7 254 160
  END
  CLASS
    NAME "(10 20)"
    EXPRESSION ([pixel] < 20)
    COLOR 7 254 55
  END
  CLASS
    NAME "(20 30)"
    EXPRESSION ([pixel] < 30)
    COLOR 44 254 6
    END
  CLASS
    NAME "(30 40)"
    EXPRESSION ([pixel] < 40)
    COLOR 160 254 6
  END
  CLASS
    NAME "(40 50)"
    EXPRESSION ([pixel] < 50)
    COLOR 254 221 5
  END
  CLASS
    NAME "(> 50)"
    EXPRESSION ([pixel] > 50)
    COLOR 254 95 4
 END        &nb
sp;        &nb
sp;
END
END # of map file
Tony Jolibois
CLS
Direction Océanographie Spatiale/Département Produits et Services
8-10 rue Hermes
31526 Ramonville-St-Agne Cedex
France
Tel: (+33) 05 61 39 37 97
Fax: (+33)05 61 39 37 82
Content-Type: text/html; charset=us-ascii
Content-Transfer-Encoding: 7bit
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
  <title></title>
</head>
<body text="#000000" bgcolor="#ffffff">
<title></title>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; Hi all,<br>
<br>
I'm a little new to mapserver.<br>
imagexy or something with&nbsp; the place of the image.<br>
/data/out3.png".<br>
"returned".<br>
<br>
Someone has an idea about it ?<br>
<br>
Thanks in advance,<br>
Tony Jolibois<br>
<br>
The map file I use for the mapserver :<br>
<br>
MAP<br>
&nbsp; NAME&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; EX2.1_<br>
&nbsp; IMAGETYPE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; png<br>
&nbsp; EXTENT&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0 -80 360 80<br>
&nbsp; SIZE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1000 500<br>
&nbsp; SHAPEPATH&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; "/var/www/html/tutorial/data"<br>
&nbsp; SYMBOLSET&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; "symbols/symbols35.sym"<br>
&nbsp; FONTSET&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; "fonts/fonts.list"<br>
&nbsp; IMAGECOLOR&nbsp;&nbsp;&nbsp;&nbsp; 0 0 0<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
<br>
&nbsp; WEB<br>
&nbsp;&nbsp;&nbsp; TEMPLATE&nbsp; 'example-cls.html'<br>
&nbsp;&nbsp;&nbsp; IMAGEPATH '/var/www/html/tutorial/data/tmp/'<br>
&nbsp;&nbsp;&nbsp; IMAGEURL&nbsp; '/tmp/'<br>
&nbsp; END<br>
&nbsp;&nbsp;&nbsp;
<br>
CONFIG DODS_BLOCK_ORIENTED "1"<br>
CONFIG DODS_AIS_FILE "ocean_ais3.xml"<br>
<br>
LAYER<br>
&nbsp; NAME grid1<br>
&nbsp; TYPE raster<br>
&nbsp; STATUS default<br>
&nbsp; DATA
'<a class="moz-txt-link-freetext"
 href="http://opendap.aviso.oceanobs.com/dodsC/merged/h/msla_oer_merged_h?Grid_0001%5B0">http://opendap.aviso.oceanobs.com/dodsC/merged/h/msla_oer_merged_h?Grid_0001[0</a>][lon][lat]'<br>
&nbsp; PROCESSING "SCALE=-100,1000"<br>
&nbsp; CLASS<br>
&nbsp;&nbsp;&nbsp; NAME "(&lt; -50cm)"<br>
&nbsp;&nbsp;&nbsp; EXPRESSION ([pixel] &lt; -50)<br>
&nbsp;&nbsp;&nbsp; COLOR 238 5 254<br>
&nbsp; END<br>
&nbsp; CLASS<br>
&nbsp;&nbsp;&nbsp; NAME "(-50 -40)"<br>
&nbsp;&nbsp;&nbsp; EXPRESSION ([pixel] &lt; -40)<br>
&nbsp;&nbsp;&nbsp; COLOR 150 5 254<br>
&nbsp; END<br>
&nbsp; CLASS<br>
&nbsp;&nbsp;&nbsp; NAME "(-40 -30)"<br>
&nbsp;&nbsp;&nbsp; EXPRESSION ([pixel] &lt; -30)<br>
&nbsp;&nbsp;&nbsp; COLOR 50 5 254<br>
&nbsp; END<br>
&nbsp; CLASS<br>
&nbsp;&nbsp;&nbsp; NAME "(-30 -20)"<br>
&nbsp;&nbsp;&nbsp; EXPRESSION ([pixel] &lt; -20)<br>
&nbsp;&nbsp;&nbsp; COLOR 6 64 254<br>
&nbsp; END<br>
&nbsp; CLASS<br>
&nbsp;&nbsp;&nbsp; NAME "(-20 -10)"<br>
&nbsp;&nbsp;&nbsp; EXPRESSION ([pixel] &lt; -10)<br>
&nbsp;&nbsp;&nbsp; COLOR 6 159 254<br>
&nbsp; END<br>
&nbsp; CLASS<br>
&nbsp;&nbsp;&nbsp; NAME "(-10 0)"<br>
&nbsp;&nbsp;&nbsp; EXPRESSION ([pixel] &lt; 0)<br>
&nbsp;&nbsp;&nbsp; COLOR 7 254 240<br>
&nbsp; END<br>
&nbsp; CLASS<br>
&nbsp;&nbsp;&nbsp; NAME "(0 10)"<br>
&nbsp;&nbsp;&nbsp; EXPRESSION ([pixel] &lt; 10)<br>
&nbsp;&nbsp;&nbsp; COLOR 7 254 160<br>
&nbsp; END<br>
&nbsp; CLASS<br>
&nbsp;&nbsp;&nbsp; NAME "(10 20)"<br>
&nbsp;&nbsp;&nbsp; EXPRESSION ([pixel] &lt; 20)<br>
&nbsp;&nbsp;&nbsp; COLOR 7 254 55<br>
&nbsp; END<br>
&nbsp; CLASS<br>
&nbsp;&nbsp;&nbsp; NAME "(20 30)"<br>
&nbsp;&nbsp;&nbsp; EXPRESSION ([pixel] &lt; 30)<br>
&nbsp;&nbsp;&nbsp; COLOR 44 254 6<br>
&nbsp; &nbsp; END<br>
&nbsp; CLASS<br>
&nbsp;&nbsp;&nbsp; NAME "(30 40)"<br>
&nbsp;&nbsp;&nbsp; EXPRESSION ([pixel] &lt; 40)<br>
&nbsp;&nbsp;&nbsp; COLOR 160 254 6<br>
&nbsp; END<br>
&nbsp; CLASS<br>
&nbsp;&nbsp;&nbsp; NAME "(40 50)"<br>
&nbsp;&nbsp;&nbsp; EXPRESSION ([pixel] &lt; 50)<br>
&nbsp;&nbsp;&nbsp; COLOR 254 221 5<br>
&nbsp; END<br>
&nbsp; CLASS<br>
&nbsp;&nbsp;&nbsp; NAME "(&gt; 50)"<br>
&nbsp;&nbsp;&nbsp; EXPRESSION ([pixel] &gt; 50)<br>
&nbsp;&nbsp;&nbsp; COLOR 254 95 4<br>
&nbsp;END&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&am
p;nb
sp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&am
p;nb
<br>
END&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; <br>
<br>
END # of map file<br>
<br>
<br>
<font face="@Arial Unicode MS">~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~<br>
Tony Jolibois<br>
CLS<br>
Direction Oc&eacute;anographie Spatiale/D&eacute;partement Produits et Services<br>
8-10 rue Hermes<br>
31526 Ramonville-St-Agne Cedex<br>
France<br>
Tel: (+33) 05 61 39 37 97<br>
Fax: (+33)05 61 39 37 82<br>
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~</font><br>
</body>
</html>
--------------090405080304070304050505--
Content-Type: image/png;
 name="out3.png"
Content-Transfer-Encoding: base64
Content-Disposition: inline;
 filename="out3.png"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--------------020106090403090101090809--
