[Mapserver-users] RED 'X' - This is the map - Image not appearing
Trent Burton tburton at holonics.ca
Thu Jul 8 08:02:23 EDT 2004
This is a multi-part message in MIME format.
------_=_NextPart_001_01C464E3.6DA0429A
Content-Type: text/plain;
	charset="US-ASCII"
Content-Transfer-Encoding: quoted-printable
I tried to install Mapserver and the workshop demo on my home
workstation and everything shows up fine in the default browser, except
the map.  I get the well known little red 'X' in the top left hand
corner with a 'this is the map' statement next to it.  The images for
the legend and the reference map show up fine.  All images, including
the map image itself, is being successfully created in my tmp directory.
The legend and reference map are being rendered in the default browser
correctly.
=20
If I click on the red 'X', maybe 2 or 3 times, an image will appear
(although it appears those clicks have resulted in zooming in).  This
originally appeared on mapserver 4.0, but I downloaded 4.2 and got the
same results.  I have a map file that I have been using at work (where I
did not have this issue) that I tried at home and I get the same kind of
behaviour.
=20
I am running Windows 2000 Professional at home.  Could this be a browser
issue?  Why would it successfully display the legend and reference map
in my browser, but not my map image when all 3 files are in my tmp
directory?  I do a view source on the browser page and the path appears
to be correct to pick up the image.
=20
Any ideas anyone?
=20
Thanks,
=20
Trent Burton
Content-Type: text/html;
	charset="US-ASCII"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE>Message</TITLE>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Dus-ascii">
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR></HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D459305011-08072004>I =
tried to install=20
Mapserver and the workshop demo on my home workstation and everything =
shows up=20
fine in the default browser, except the map.&nbsp; I get the well known =
little=20
red 'X'&nbsp;in the top left hand corner with a 'this is the map' =
statement next=20
to it.&nbsp; The images for the legend and the reference map show up =
fine.&nbsp;=20
All images, including the map image itself, is being successfully =
created in my=20
tmp directory.&nbsp; The legend and reference map are being rendered in =
the=20
default browser correctly.</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN=20
class=3D459305011-08072004></SPAN></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D459305011-08072004>If I =
click on the=20
red 'X', maybe 2 or 3 times, an image will appear (although it appears =
those=20
clicks have resulted in zooming in).&nbsp; This originally appeared on =
mapserver=20
4.0, but I downloaded 4.2 and got the same results.&nbsp; I have a map =
file that=20
I have been using at work (where I did not have this issue) that I tried =
at home=20
and I get the same kind of behaviour.</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D459305011-08072004>I am =
running Windows=20
2000 Professional at home.&nbsp; Could this be a browser issue?&nbsp; =
Why would=20
it successfully display the legend and reference map in my browser, but =
not my=20
map image when all 3 files are in my tmp directory?&nbsp; I do a view =
source on=20
the browser page and the path appears to be correct to pick up the=20
image.</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D459305011-08072004>Any =
ideas=20
anyone?</SPAN></FONT></DIV>
class=3D459305011-08072004>Thanks,</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D459305011-08072004>Trent=20
Burton</SPAN></FONT></DIV></BODY></HTML>
=00
------_=_NextPart_001_01C464E3.6DA0429A--
