[Mapserver-users] Problem in installing Proj4 and GDAL for Linux RH Advanced Server
Mon Jul 12 09:26:32 EDT 2004
Taha Al Sayed wrote:
> Dear All
> I'm trying to install the demo from map server on a Linux box with Red hat Advanced server. I managed to get it to work only with shp files (after some modifications). So far I'm not able to get the projection to work neither the GDAL. I have installed the packages for GDAL and Proj4 and then included then in the configuration of the mapserver using <--with-gdal --with-proj>. When I test the proj4 and gdal packages seperately they seem to work, but from map the server they don't, although the configuration in mapserver doesn't give any error messages.
Taha,
This report doesn't give us much to go on to help you work out the problem.
What does "mapserv -v" report?  What does "ldd mapserv" report?  What
makes you think the projections aren't working?
Best regards,
