[Mapserver-users] question about legendurl_href in the history.txt
file
Daniel Morissette
dmorissette at dmsolutions.ca
Tue Jul 13 00:39:56 EDT 2004
Pagurek, Debbie wrote:
> Could someone explain what the following note means? It is in the history.txt document that is released with mapserver 4.2.
> I can't make sense of it or how to implement legendurl_href.
> "Replace wms_style_%s_legendurl, wms_logourl, wms_descriptionurl, wms_dataurl
> and wms_metadataurl metadata by four new metadata by metadata replaced. The
> new metadata are called legendurl_width, legendurl_height, legendurl_format,
> legendurl_href, logourl_width, etc...
> Old dependancy to the metadata with four value in it , space separated, are
> not kept."
Ouch! That's a bad one... I had to re-read it almost 10 times to make
sense of it...
First of all, you can't implement legendurl_href in WMS Capabilites yet,
the comment above applies only to WMS context, the support of LegendURL
in the WMS capabilities is still an open issue, see
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=438
IIRC, what the comment above tries to say is that the following metadata
were used before by the WMS context code, and that each of them used to
expect a different number of parameters delimited by spaces:
wms_logourl
wms_descriptionurl
wms_dataurl
wms_metadataurl
This was a mess since some of the above included 4 space-delimited
values (width, height, format, url) and some included only 2 (only
format and url since width/height don't make sense for DataUrl for
instance), so each of the above was replaced by a set of 4 metadata
entries instead.
e.g.
wms_style_%s_legendurl has been replaced with:
wms_style_%s_legendurl_width
wms_style_%s_legendurl_height
wms_style_%s_legendurl_format
wms_style_%s_legendurl_href
wms_logourl has been replaced with:
wms_logourl_width
wms_logourl_height
wms_logourl_format
wms_logourl_href
... and so on for each of the 5 old metadata values above that were
split into 4 values the same way.
I'll copy this explanation to the bug.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
