[Mapserver-users] Setting a projection
kgrootendorst at baird.com
Tue Jul 13 16:07:54 EDT 2004
This is a multipart message in MIME format.
--=_alternative 006E97E685256ED0_=
Content-Type: text/plain; charset="US-ASCII"
Hello all,
I have a custom Lambert Conformal Conic projection that I want to define
in my application.
However, I haven't been able to come up with the correct syntax in the
PROJECTION ....END tags yet (my map will not draw with my projection info
- if I remove it, it draws fine.)
The parameters are as follows:
PROJCS["IJC Lake Ontario Lambert Conformal
Conic",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",6200000.0],PARAMETER["False_Northing",2958000.0],PARAMETER["Central_Meridian",-91.8666],PARAMETER["Standard_Parallel_1",49.0],PARAMETER["Standard_Parallel_2",77.0],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",63.0],UNIT["Meter",1.0]]
Thanks.
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Hello all,</font>
<br><font size=2 face="sans-serif">I have a custom Lambert Conformal Conic
projection that I want to define in my application.</font>
<br><font size=2 face="sans-serif">However, I haven't been able to come
up with the correct syntax in the PROJECTION ....END tags yet (my map will
not draw with my projection info - if I remove it, it draws fine.)</font>
<br><font size=2 face="sans-serif">The parameters are as follows:</font>
<br>
<br><font size=2 face="sans-serif">PROJCS["IJC Lake Ontario Lambert
Conformal Conic",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",6200000.0],PARAMETER["False_Northing",2958000.0],PARAMETER["Central_Meridian",-91.8666],PARAMETER["Standard_Parallel_1",49.0],PARAMETER["Standard_Parallel_2",77.0],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",63.0],UNIT["Meter",1.0]]</font>
<br>
<br><font size=2 face="sans-serif">Thanks.<br>
</font>
--=_alternative 006E97E685256ED0_=--
