[Mapserver-users] query by record num
Steve Lime
steve.lime at dnr.state.mn.us
Wed Jul 14 01:24:17 EDT 2004
There is also a INDEXQUERY CGI mode and there may well be a
corresponding mapscript method.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Eric Bridger <eric at gomoos.org> 07/13/04 2:58 PM >>>
On Tue, 2004-07-13 at 13:41, Nikolai Vladychevski wrote:
> Hello,
> I have a shapefiles with lines or polygons and I want to query an item
by
> its sequencial number in the shapefile, for example, I want to select
the
> polygon number 239 on the map. I don't have any unique identifier in
the DBF
> file. Can be a shape queried by its record number? If so how? I supose
I
> need to use queryByAttributes(string qitem, string qstring, int mode)
call,
> but how do I tell it to search by record number?
I'm assuming you're using mapscript.
The Layer object has a getShape(tileindex, shapeindex) method so you
could do: $shape = $layer->getShape(-1, 239). But I guess the real
question is how to change the attributes on that shape? You could try
getting the Layer's Class's Style object and setting its color
attributes then calling $shape->draw(). After you've already drawn the
layer.
Eric
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
