[Mapserver-users] symbol question
IMD Listuser imd_listuser at comcast.net
Wed Jul 14 07:30:46 EDT 2004
A follow-on question for symbols.
Id like to use a SYMBOL object to depict points retrieved using OGR
VirtualSpatialData connection to a SQL Server DB.
I would like to rotate the symbol (an arrow) according to a secondary
field in the table row. I would also like to label the point with
additional fields from the table row.
>From what Ive been able to search the list archives, other users have
tried this with no success (or at least no response).
Thanks
Charlie
Charlie Van Dusen
charlie at im-design.net
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Steve Lime
Sent: Wednesday, July 14, 2004 1:34 AM
To: fx.gamoy at mapxplore.com
Cc: mapserver at geochem.de; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] symbol question
See the attached zip file. There's a super simple example with an output
image. Should be what you need. You'll need to edit the font file first
to run it with shp2img.
Steve
>>> "fx gamoy" <fx.gamoy at mapxplore.com> 07/13/04 1:11 AM >>>
thanks a lot
that's it i need
fx
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>; <fx.gamoy at mapxplore.com>
Sent: Tuesday, July 13, 2004 6:02 AM
> I'll see if I can whip up a demo. I've used the technique to place
> railroad ties on a line so they would always be perpendicular so I'm
> thinkin this is what you want...
> Steve
> >>> "fx gamoy" <fx.gamoy at mapxplore.com> 07/10/04 3:50 AM >>>
> hello
> thanks for your post
> but what is the way to use truetype line symbol in the mapfile?
> fx
> From: "Steve Lime" <steve.lime at dnr.state.mn.us>
> To: <fx.gamoy at mapxplore.com>
> Sent: Friday, July 09, 2004 7:27 PM
> > You need to look at TrueType line symbols, I believe they
> automatically
> > are rotated
> > to match the orientation of a line.
> > Steve
> > >>> "fx gamoy" <fx.gamoy at mapxplore.com> 7/9/2004 11:11:08 AM >>>
> > Hello world,
> > i'd like to obtain lines with oriented triangle in order to show the
> > direction of a track.
> > I have made several test but nothing very interesting..
> > thanks in advance..
> > fx
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
