[Mapserver-users] PHP/Mapscript imageObj
Yewondwossen Assefa assefa at dmsolutions.ca
Wed Jul 14 11:29:05 EDT 2004
Function saveimage can now take a map object as a second non mandatory
argument.
Ex :  $img->saveImage("c:/msapps/gmap/htdocs/ttt2.tif", $oMap);
I have tested it with one test file. Please verfify it works for you
(The Bug number related to this is 772).
Later,
Don Drake wrote:
> Excellent, I look forward to it.
> Thanks.
> -Don
> On Tue, 13 Jul 2004 17:03:20 -0400, Yewondwossen Assefa
> <assefa at dmsolutions.ca> wrote:
>>I have entered a Bug 772 in mapserver and It will be adressed before
>>next relase.
>>Later,
>>Don Drake wrote:
>>>I was wondering if there are any plans to update the PHP/Mapscript
>>>libraries to get them more in sync with the Perl/Python versions.
>>>I was trying to generate GeoTiffs with PHP/Mapscript and ran into some
>>>troubles.  It would generate the .tiff file just fine, but there was
>>>no geo-information embedded when inspecting with gdalinfo.
>>>I tracked the problem down to the imageObj not taking a map reference
>>>as a parameter when saving.  The Perl module does, and uses the
>>>projection information of the map as a data source for the GeoTifff's
>>>reference points and datum.
>>>I was able to convert my PHP code to Perl/Mapscript to get this to
>>>work, but would really like a single-code base (language) for my
>>>project.
>>>Thanks.
>>>-Don Drake
>>>Donald Drake
>>>President
>>>Drake Consulting
>>>http://www.drakeconsult.com/
>>>312-560-1574
>>>_______________________________________________
>>>Mapserver-users mailing list
>>>Mapserver-users at lists.gis.umn.edu
>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>>Assefa Yewondwossen
>>Software Analyst
>>Email: assefa at dmsolutions.ca
>>http://www.dmsolutions.ca/
>>Phone: (613) 565-5056 (ext 14)
>>Fax:   (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax:   (613) 565-0925
