[Mapserver-users] Reprojecting Problem
kgrootendorst at baird.com kgrootendorst at baird.com
Wed Jul 14 17:09:53 EDT 2004
This is a multipart message in MIME format.
--=_alternative 0074454185256ED1_=
Content-Type: text/plain; charset="US-ASCII"
Ed,
I did what you suggested, and the shoreline displayed fine in UTM extents.
Kevin
"Ed McNierney" <ed at topozone.com>
07/14/2004 01:34 PM
To
<kgrootendorst at baird.com>
cc
<mapserver-users at lists.gis.umn.edu>
Subject
RE: [Mapserver-users] Reprojecting Problem
Kevin -
Thanks; I'd suggest next modifying the MAP file to comment out ALL
PROJECTION blocks, and turn off all the layers except the shore line.
You'll need to adjust the EXTENT to have the right values in UTM
coordinates, but this should get you a UTM-output map of the shoreline.
I'm trying to make sure that all your data is valid and is really in the
projection you think it is.
    - Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
From: kgrootendorst at baird.com [mailto:kgrootendorst at baird.com]
Sent: Wednesday, July 14, 2004 12:45 PM
To: Ed McNierney
Cc: mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] Reprojecting Problem
Ed,
Yes, it supports proj, and the other layers look okay.  These other layers
are in the same projection as the map object.
The custom projection I'm using in the map is as follows:
# Custom Lambert Conformal Conic
<50000> +proj=lcc +lat_1=49 +lat_2=63 +lat_0=49 +lon_0=-91.86 +x_0=6200000
+y_0=2958000 +ellps=GRS80 +datum=NAD83 +units=m +no_defs  no_defs <>
I've had no problems using this projection with ArcMap.
I'm running the following:
Mapserver 4.2
PHP 4.3.4
Win2000
Kevin
07/14/2004 10:50 AM
To
<kgrootendorst at baird.com>, <mapserver-users at lists.gis.umn.edu>
cc
Subject
[SPAM] - RE: [Mapserver-users] Reprojecting Problem - Email found in
subject
Kevin -
Do all your other layers look OK in the output map?  BTW, I think it's
good practice to include a PROJECTION block in ALL layers if they're not
all the same projection.
If you run "mapserv -v" from the command line, does it show
"SUPPORTS=PROJ"?
    - Ed
Ed McNierney
ed at topozone.com
(978) 251-4242
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
Sent: Wednesday, July 14, 2004 10:17 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Reprojecting Problem
Hello,
I'm having trouble with reprojecting in Mapserver.  I'm trying to
reproject my 'shoreline' file (defined as UTM 17N NAD83) to my map, which
has been defined with a customized lambert conformal conic projection.
Based on my Mapfile below, can anyone see why my data will not re-project?
 Am I missing something?  I thought everything looked okay, but obviously
something must be wrong!
MAP
 NAME "test"
 STATUS ON
 EXTENT 6000000 600000 9000000 1500000
 #Minx Miny Maxx Maxy
 SIZE 600 400
 SHAPEPATH "./Data"
 SYMBOLSET "./etc/symbols.sym"
 FONTSET "./etc/fonts.txt"
 IMAGETYPE PNG
 UNITS METERS
 WEB
   IMAGEPATH "C:/Program Files/Apache Group/Apache2/htdocs/ms_tmp/"
   IMAGEURL "/ms_tmp/"
 END
 PROJECTION
   "init=epsg:50000"     #Custom LCC Projection - defined in proj/epsg
 END
LEGEND
   STATUS ON
   IMAGECOLOR 255 255 255
   POSITION LL
   KEYSIZE 18 12
   KEYSPACING 5 5
 END
 SCALEBAR
   STATUS ON
   COLOR 255 255 255
   OUTLINECOLOR 0 0 0
   BACKGROUNDCOLOR 0 0 0
   UNITS KILOMETERS
   INTERVALS 5
   SIZE 150 10
   STYLE 0
   POSITION LL
 END
 LAYER
   NAME "ec_counties_LCC"
   STATUS ON
   DATA "./ec_counties_LCC"
   TYPE POLYGON
   UNITS METERS
   SIZEUNITS PIXELS
   CLASS
     TEMPLATE "ttt"
     STYLE
       SYMBOL 0
       COLOR 211 255 190
       OUTLINECOLOR 0 0 0
     END
   END
 END
 LAYER
   NAME "New_York_County"
   STATUS ON
   DATA "./New_York_County"
   TYPE POLYGON
   #LABELITEM "NAME"
   CLASS
     #NAME "New_York_County"
     TEMPLATE "ttt"
     LABEL
       TYPE bitmap
       FONT "arial"
       SIZE small
       POSITION CC
       COLOR 255 0 0
     END
     STYLE
       SYMBOL 0
       COLOR 252 241 207
       OUTLINECOLOR 0 0 0
     END
   END
 END
 LAYER
   NAME "Shoreline_UTM"
   STATUS ON
   DATA "./Shoreline_UTM"
   TYPE LINE
   UNITS METERS
   SIZEUNITS PIXELS
   PROJECTION
     "init=epsg:26917"      #UTM Zone 17N NAD 83
   END
   CLASS
     STYLE
       SYMBOL 0
       COLOR 0 0 255
     END
   END
 END
END
Thanks.
Kevin
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Ed,</font>
<br><font size=2 face="sans-serif">I did what you suggested, and the shoreline
displayed fine in UTM extents.</font>
<br>
<br><font size=2 face="sans-serif">Kevin<br>
</font>
<br>
<br>
<br>
<table width=100%>
<tr valign=top>
<td width=40%><font size=1 face="sans-serif"><b>&quot;Ed McNierney&quot;
&lt;ed at topozone.com&gt;</b> </font>
<p><font size=1 face="sans-serif">07/14/2004 01:34 PM</font>
<td width=59%>
<table width=100%>
<tr>
<td>
<div align=right><font size=1 face="sans-serif">To</font></div>
<td valign=top><font size=1 face="sans-serif">&lt;kgrootendorst at baird.com&gt;</font>
<tr>
<td>
<div align=right><font size=1 face="sans-serif">cc</font></div>
<td valign=top><font size=1 face="sans-serif">&lt;mapserver-users at lists.gis.umn.edu&gt;</font>
<tr>
<td>
<div align=right><font size=1 face="sans-serif">Subject</font></div>
<td valign=top><font size=1 face="sans-serif">RE: [Mapserver-users] Reprojecting
Problem</font></table>
<br>
<table>
<tr valign=top>
<td>
<td></table>
<br></table>
<br>
<br>
<br><font size=2 color=blue face="Arial">Kevin -</font>
<br><font size=3>&nbsp;</font>
<br><font size=2 color=blue face="Arial">Thanks; I'd suggest next modifying
the MAP file to comment out ALL PROJECTION blocks, and turn off all the
layers except the shore line. &nbsp;You'll need to adjust the EXTENT to
have the right values in UTM coordinates, but this should get you a UTM-output
map of the shoreline. &nbsp;I'm trying to make sure that all your data
is valid and is really in the projection you think it is.</font>
<br><font size=3>&nbsp; &nbsp; </font><font size=2 color=blue face="Arial">-
Ed</font>
<p><font size=2>Ed McNierney<br>
President and Chief Mapmaker<br>
TopoZone.com / Maps a la carte, Inc.<br>
73 Princeton Street, Suite 305<br>
North Chelmsford, MA &nbsp;01863<br>
ed at topozone.com<br>
(978) 251-4242 </font>
<p>
<br>
<hr><font size=2 face="Tahoma"><b>From:</b> kgrootendorst at baird.com [mailto:kgrootendorst at baird.com]
<b><br>
Sent:</b> Wednesday, July 14, 2004 12:45 PM<b><br>
To:</b> Ed McNierney<b><br>
Cc:</b> mapserver-users at lists.gis.umn.edu<b><br>
Subject:</b> RE: [Mapserver-users] Reprojecting Problem</font><font size=3><br>
</font>
<br><font size=2 face="sans-serif"><br>
Ed,</font><font size=3> </font><font size=2 face="sans-serif"><br>
Yes, it supports proj, and the other layers look okay. &nbsp;These other
layers are in the same projection as the map object.</font><font size=3>
The custom projection I'm using in the map is as follows:</font><font size=3>
# Custom Lambert Conformal Conic</font><font size=3> </font><font size=2 face="sans-serif"><br>
&lt;50000&gt; +proj=lcc +lat_1=49 +lat_2=63 +lat_0=49 +lon_0=-91.86 +x_0=6200000
+y_0=2958000 +ellps=GRS80 +datum=NAD83 +units=m +no_defs &nbsp;no_defs
&lt;&gt;</font><font size=3> </font><font size=2 face="sans-serif"><br>
I've had no problems using this projection with ArcMap.</font><font size=3>
<br>
I'm running the following:</font><font size=3> </font><font size=2 face="sans-serif"><br>
Mapserver 4.2</font><font size=3> </font><font size=2 face="sans-serif"><br>
PHP 4.3.4</font><font size=3> </font><font size=2 face="sans-serif"><br>
Win2000</font><font size=3> <br>
Kevin<br>
<br>
<br>
</font>
<table width=100%>
<tr valign=top>
<td width=34%><font size=1 face="sans-serif"><b>&quot;Ed McNierney&quot;
<p><font size=1 face="sans-serif">07/14/2004 10:50 AM</font><font size=3>
</font>
<td width=65%>
<br>
<table width=100%>
<tr>
<td width=13%>
<td width=86% valign=top><font size=1 face="sans-serif">&lt;kgrootendorst at baird.com&gt;,
&lt;mapserver-users at lists.gis.umn.edu&gt;</font><font size=3> </font>
<tr>
<td>
<td valign=top>
<tr>
<td>
<td valign=top><font size=1 face="sans-serif">[SPAM] - RE: [Mapserver-users]
Reprojecting Problem - Email found in subject</font></table>
<br>
<br>
<table width=100%>
<tr valign=top>
<td width=49%>
<td width=50%></table>
<br></table>
<br><font size=3><br>
<br>
</font><font size=2 color=blue face="Arial"><br>
Kevin -</font><font size=3> <br>
 &nbsp;</font><font size=2 color=blue face="Arial"><br>
Do all your other layers look OK in the output map? &nbsp;BTW, I think
it's good practice to include a PROJECTION block in ALL layers if they're
not all the same projection.</font><font size=3> <br>
If you run &quot;mapserv -v&quot; from the command line, does it show &quot;SUPPORTS=PROJ&quot;?</font><font size=3>
<br>
 &nbsp; &nbsp;- Ed</font><font size=3> </font>
<p><font size=2 color=blue face="Arial">Ed McNierney<br>
<p><font size=3><br>
</font>
<hr><font size=2 face="Tahoma"><b>From:</b> mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu] <b>On Behalf Of </b>kgrootendorst at baird.com<b><br>
Sent:</b> Wednesday, July 14, 2004 10:17 AM<b><br>
To:</b> mapserver-users at lists.gis.umn.edu<b><br>
Subject:</b> [Mapserver-users] Reprojecting Problem</font><font size=3><br>
<br>
Hello,</font><font size=3> </font><font size=2 face="sans-serif"><br>
I'm having trouble with reprojecting in Mapserver. &nbsp;I'm trying to
has been defined with a customized lambert conformal conic projection.</font><font size=3>
&nbsp;Am I missing something? &nbsp;I thought everything looked okay, but
obviously something must be wrong!</font><font size=3> </font><font size=2 face="sans-serif"><br>
</font><font size=2 face="Courier New"><br>
<br>
MAP</font><font size=3> </font><font size=2 face="Courier New"><br>
 NAME &quot;test&quot;</font><font size=3> </font><font size=2 face="Courier New"><br>
 STATUS ON</font><font size=3> </font><font size=2 face="Courier New"><br>
 EXTENT 6000000 600000 9000000 1500000 <br>
 #Minx Miny Maxx Maxy</font><font size=3> </font><font size=2 face="Courier New"><br>
 SIZE 600 400 <br>
 SHAPEPATH &quot;./Data&quot;</font><font size=3> </font><font size=2 face="Courier New"><br>
 SYMBOLSET &quot;./etc/symbols.sym&quot;</font><font size=3> </font><font size=2 face="Courier New"><br>
 FONTSET &quot;./etc/fonts.txt&quot;</font><font size=3> </font><font size=2 face="Courier New"><br>
 IMAGETYPE PNG</font><font size=3> </font><font size=2 face="Courier New"><br>
 UNITS METERS</font><font size=3> </font><font size=2 face="Courier New"><br>
 WEB</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; IMAGEPATH &quot;C:/Program Files/Apache Group/Apache2/htdocs/ms_tmp/&quot;</font><font size=3>
 &nbsp; IMAGEURL &quot;/ms_tmp/&quot;</font><font size=3> </font><font size=2 face="Courier New"><br>
 END</font><font size=3> </font><font size=2 face="Courier New"><br>
 PROJECTION</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; &quot;init=epsg:50000&quot; &nbsp; &nbsp; #Custom LCC Projection
- defined in proj/epsg</font><font size=3> </font><font size=2 face="Courier New"><br>
LEGEND</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; STATUS ON</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; IMAGECOLOR 255 255 255</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; POSITION LL</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; KEYSIZE 18 12 <br>
 &nbsp; KEYSPACING 5 5 <br>
 SCALEBAR</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; COLOR 255 255 255</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; OUTLINECOLOR 0 0 0</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; BACKGROUNDCOLOR 0 0 0</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; UNITS KILOMETERS</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; INTERVALS 5</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; SIZE 150 10 <br>
 &nbsp; STYLE 0</font><font size=3> </font><font size=2 face="Courier New"><br>
 LAYER</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; NAME &quot;ec_counties_LCC&quot;</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; DATA &quot;./ec_counties_LCC&quot;</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; TYPE POLYGON</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; UNITS METERS</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; SIZEUNITS PIXELS</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; CLASS</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; &nbsp; NAME &quot;ec_counties_LCC&quot;</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; &nbsp; TEMPLATE &quot;ttt&quot;</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; &nbsp; STYLE</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; &nbsp; &nbsp; SYMBOL 0</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; &nbsp; &nbsp; COLOR 211 255 190</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; &nbsp; &nbsp; OUTLINECOLOR 0 0 0</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; &nbsp; END</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; NAME &quot;New_York_County&quot;</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; DATA &quot;./New_York_County&quot;</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; #LABELITEM &quot;NAME&quot;</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; &nbsp; #NAME &quot;New_York_County&quot;</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; &nbsp; LABEL</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; &nbsp; &nbsp; TYPE bitmap</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; &nbsp; &nbsp; FONT &quot;arial&quot;</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; &nbsp; &nbsp; SIZE small</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; &nbsp; &nbsp; POSITION CC</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; &nbsp; &nbsp; COLOR 255 0 0</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; &nbsp; &nbsp; COLOR 252 241 207</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; NAME &quot;Shoreline_UTM&quot;</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; DATA &quot;./Shoreline_UTM&quot;</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; TYPE LINE</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; PROJECTION</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; &nbsp; &quot;init=epsg:26917&quot; &nbsp; &nbsp; &nbsp;#UTM Zone
17N NAD 83</font><font size=3> </font><font size=2 face="Courier New"><br>
 &nbsp; &nbsp; &nbsp; COLOR 0 0 255</font><font size=3> </font><font size=2 face="Courier New"><br>
END</font><font size=3> </font><font size=2 face="sans-serif"><br>
<br>
Thanks.</font><font size=3> </font><font size=2 face="sans-serif"><br>
<br>
Kevin</font><font size=3> </font>
<p>
--=_alternative 0074454185256ED1_=--
