[Mapserver-users] It's working now --->trying to load php dll's
Javier Castillejo Montes jcastil1 at tragsa.es
Thu Jul 15 03:21:26 EDT 2004
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C46A3C.5B08ACF6
Content-Type: text/plain;
	charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Thanks you all, DEAN, Step=E1n and Merlos
=20
The problem was in the path, I had the dll's but It wasn't on the rigth
place...
=20
It's a pleasure work whit all of you!!!
=20
Thanks gang, you all make the job easy.
-----Mensaje original-----
De: DEAN Jeremy E [mailto:Jeremy.E.DEAN at Co.Benton.OR.US]
Enviado el: mi=E9rcoles, 14 de julio de 2004 17:37
Para: Javier Castillejo Montes; Mapserver-users at lists.gis.umn.edu
Asunto: RE: [Mapserver-users]
Hello,
=20
I am assuming you are trying to install on a Windows OS.  If this is =
the
case you need to make sure you have the php_mapscript.dll in your
<Drive>:\WINDOWS\System32\ folder (can be WINNT\System32 depending on =
what
you are using) along with 9 necessary DLL's that MapScript uses.  These
should be bundled in 6 zip files that are included in the standard =
binary
download.
=20
> The dll "php_mapscript.dll" looks as it was walking away.. I mean, an
error rise when I try to load it: "Unable to load php_mapscript.dll <=20
After that is done you should just have to add:
=20
extension=3Dphp_mapscript.dll
=20
to your PHP.ini file, wherever it resides.
> In the "extension_dir" of "php.ini" I put the path where
"php_mapscript.dll" is, so I actually have the dll. (I checked it and =
it's
there) <
=20
Also, I have always used the phpinfo( ) call as a quick way to test if =
my
installation worked.
=20
Hope this helps,
Jeremy Dean=20
Benton County IRM=20
Programmer/Analyst=20
[541] 766-6610=20
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<TITLE>Hi all.... here is my problem.... trying to load php =
dll's</TITLE>
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR></HEAD>
<BODY>
<DIV><FONT face=3DArial color=3D#0000ff size=3D2><SPAN =
class=3D241061807-15072004>Thanks=20
you all, DEAN, &#352;tep=E1n&nbsp;and Merlos</SPAN></FONT></DIV>
<DIV><FONT face=3DArial color=3D#0000ff size=3D2><SPAN=20
class=3D241061807-15072004></SPAN></FONT>&nbsp;</DIV>
class=3D241061807-15072004>The=20
problem was in the path, I had the dll's but It wasn't on the rigth=20
place...</SPAN></FONT></DIV>
class=3D241061807-15072004>It's a=20
pleasure work whit all of you!!!</SPAN></FONT></DIV>
gang, you all make the job easy.</SPAN></FONT></DIV>
<BLOCKQUOTE dir=3Dltr style=3D"MARGIN-RIGHT: 0px">
  <DIV class=3DOutlookMessageHeader dir=3Dltr align=3Dleft><FONT =
face=3DTahoma=20
  size=3D2>-----Mensaje original-----<BR><B>De:</B> DEAN Jeremy E=20
  [mailto:Jeremy.E.DEAN at Co.Benton.OR.US]<BR><B>Enviado el:</B> =
mi=E9rcoles, 14 de=20
  julio de 2004 17:37<BR><B>Para:</B> Javier Castillejo Montes;=20
  Mapserver-users at lists.gis.umn.edu<BR><B>Asunto:</B> RE:=20
  [Mapserver-users]<BR></FONT></DIV>
  <DIV><SPAN class=3D789181715-14072004><FONT face=3DArial =
color=3D#0000ff=20
  size=3D2>Hello,</FONT></SPAN></DIV>
color=3D#0000ff=20
  size=3D2></FONT></SPAN>&nbsp;</DIV>
color=3D#0000ff size=3D2>I am=20
  assuming you are trying to install on a Windows OS.&nbsp; If this is =
the case=20
  you need to make sure you have the php_mapscript.dll in your=20
  &lt;Drive&gt;:\WINDOWS\System32\ folder (can be WINNT\System32 =
depending on=20
  what you are using)&nbsp;along with 9 necessary DLL's that MapScript=20
  uses.&nbsp; These should be&nbsp;bundled&nbsp;in 6 zip files that=20
  are&nbsp;included in the standard binary =
download.</FONT></SPAN></DIV>
color=3D#0000ff=20
size=3D2><SPAN=20
  class=3D789181715-14072004><FONT face=3DArial=20
  color=3D#0000ff>&gt;&nbsp;</FONT></SPAN>The dll "php_mapscript.dll" =
looks as it=20
  was walking away.. I mean, an error rise when I try to load it: =
"Unable to=20
  load php_mapscript.dll<FONT face=3DArial><FONT color=3D#0000ff><SPAN=20
  class=3D789181715-14072004>&nbsp;</SPAN><SPAN=20
class=3D789181715-14072004>&lt;&nbsp;</SPAN></FONT></FONT><BR><BR><SPAN =
  class=3D789181715-14072004><FONT face=3DArial color=3D#0000ff>After =
that is done you=20
  should just have to add:</FONT></SPAN></FONT></DIV>
face=3DArial=20
class=3D789181715-14072004></SPAN></FONT>&nbsp;</DIV>
size=3D2><SPAN=20
color=3D#0000ff>extension=3Dphp_mapscript.dll</FONT></SPAN></FONT></DIV>=
  <DIV><FONT size=3D2><SPAN class=3D789181715-14072004><FONT =
face=3DArial=20
  color=3D#0000ff></FONT></SPAN></FONT>&nbsp;</DIV>
face=3DArial=20
  color=3D#0000ff>to your PHP.ini file, wherever it resides.</DIV>
  <DIV class=3DOutlookMessageHeader dir=3Dltr=20
  align=3Dleft><BR></DIV></FONT></SPAN></FONT>
  <DIV class=3DOutlookMessageHeader dir=3Dltr style=3D"MARGIN-RIGHT: =
0px"=20
  align=3Dleft><FONT size=3D2><SPAN =
class=3D789181715-14072004></SPAN><BR><SPAN=20
  color=3D#0000ff>&gt;&nbsp;</FONT></SPAN>In the "extension_dir" of =
"php.ini" I=20
  put the path where "php_mapscript.dll" is, so I actually have the =
dll. (I=20
  checked it and it's there)<SPAN class=3D789181715-14072004><FONT =
face=3DArial=20
  color=3D#0000ff>&nbsp;&lt;</FONT></SPAN></FONT></DIV>
0px"=20
  align=3Dleft><FONT face=3DArial color=3D#0000ff size=3D2><SPAN=20
0px"=20
  class=3D789181715-14072004>Also, I have always used the phpinfo( ) =
call as a=20
  quick way to test if my installation worked.</SPAN></FONT></DIV>
0px"=20
0px"=20
  class=3D789181715-14072004>Hope this helps,</SPAN></FONT></DIV>
0px"=20
  class=3D789181715-14072004></SPAN></FONT><FONT face=3DArial =
color=3D#0000ff=20
  size=3D2><SPAN class=3D789181715-14072004><FONT face=3D"Courier New" =
size=3D2>Jeremy=20
  Dean</FONT> <BR><FONT face=3D"Courier New" size=3D2>Benton County =
IRM</FONT>=20
  <BR><FONT face=3D"Courier New" size=3D2>Programmer/Analyst</FONT> =
<BR><FONT=20
  face=3D"Courier New" size=3D2>[541] 766-6610</FONT>=20
</DIV></BLOCKQUOTE></SPAN></FONT></BODY></HTML>
------_=_NextPart_001_01C46A3C.5B08ACF6--
