[Mapserver-users] JOIN problem
Rebecca Colwell colwell at geog.umn.edu
Thu Jul 15 17:00:39 EDT 2004
Problem explained!
After searching around in bugzilla, my coworker and I came across this
Bug that answers my join question from yesterday.  Here is the link and
an excerpt from the bug posting:
	http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=674
	Querying the map does show the joined attributes so I suppose
	*on a map layer with a join you can query the joined attributes
	but you cannot use them to classify and display the layer.*
	Is this correct? If not, what am I missing and if so, wouldn't
	this be a nice enhancement?
	>>Attila Csipa
	> That is correct. I have personally suggested that enhancement
	> as well but at is turns out it is not easy to implement so it
	> will have to wait until somebody invests the time and effort.
Thank you to Randy, Dylan and David for helping troubleshoot this.
~Becky
Rebecca Colwell wrote:
> Hello all,
> I appreciate all the input I've received on my problem.  I've been
> looking into everyone's suggestions, and tried an experiment...
> To see if the issue has something to do with the expression or field
> name/case, I joined my .dbf to my shapefile, switched the DATA source
> under LAYER to the new shapefile and the expression worked like I want
> it to.  The .dbf is going to be changing over time though, so this work
> around is not my favored option.
> Any other thoughts on this?
> Thanks for all the help,
> ~Becky
> David Fawcett wrote:
>> If that doesn't work, you may want to try your field name in all caps.
>> e.g. [DISFCHMT_R]
>> This may have been dealt with many versions ago, but I seem to remember
>> that MapServer sometimes wanted field names in all caps.
>> David.
>> David J. Fawcett
>> MN Office of Environmental Assistance
>>>>> Dylan Keon <keon at nacse.org> 7/14/2004 1:19:34 PM >>>
>> There is a good explanation of EXPRESSION at
>> http://mapserver.gis.umn.edu/doc42/mapfile-reference.html#class
>> Make sure your attribute name is *exactly* as it appears in the DBF
>> file, as they are case sensitive.
>> Also, it should probably be
>>      EXPRESSION ([Disfchmt_R] <= .021)
>> instead of
>>      EXPRESSION ('[Disfchmt_R]' <= .021)
>> (remove the single quotation marks).
>> --Dylan
>> On 07/14/2004 10:50 AM, Randy James wrote:
>>> Hi Rebecca
>>> I know a bit about regex but there are people on the list
>>> that know way more than me so i am forwarding your email to
>>> the list. Its a good idea to reply to the list rather than
>>> the person who is try to give a bit of advice; that way the
>>> whole list can give feedback.
>>> Randy
>>> --- Rebecca Colwell <colwell at geog.umn.edu> wrote:
>>>> Hey Randy,
>>>> I'm struggling to understand how to make things work that
>>>> I didn't come across in the tutorial.  Would you mind breaking down the
>>>> terms regex and filter a bit for me, and maybe give me an example of
>>>> what you mean? I'm experiencing that newbie/lost feeling (I've been
>>>> trying to figure this out on my own for the last few days).
>>>> Thanks,
>>>> ~Becky
>>>> PS  Should I continue sending this dialog to the whole
>>>> list or just you? I'm new with listserv etiquette too.
>>>> Randy James wrote:
>>>>> Hi
>>>>> That it is not a join problem but maybe a regex problem
>>>> or
>>>>> something else with the filter.
>>>>> Randy
>>>>> --- Rebecca Colwell <colwell at geog.umn.edu> wrote: > Hey
>>>>> Randy,
>>>>>> Yes, it displays my US shapefile when I comment out
>>>> that
>>>>>> line.  What does this tell you?
>>>>>> Thanks!
>>>>>> ~Becky
>>>>>> Randy James wrote:
>>>>>>> Hi
>>>>>>> Will it work if you do not filter it by 'Disfchmt_R' ?
>>>>>>> Randy
>>>> Hi,
>>>>>>>> I'm trying to work through building one of my first
>>>>>> .map
>>>>>>>> files, and have hit a wall.  I can't seem to figure out how to do a
>>>>>>>> one-to-one join.  I keep getting the error messages:
>>>>>>>> msDrawMap(): Image handling error. Failed to draw
>>>> layer
>>>>>>>> named 'states'.
>>>>>>>> msDBFGetItemIndex(): DBASE file error. Item
>>>>>> 'Disfchmt_R'
>>>>>>>> not found.
>>>>>>>> I triple checked the .dbf I'm trying to join, and
>>>> that
>>>>>> is
>>>>>>>> the name of the attribute field I want to access.
>>>>>>>> Below is my short bit of code so far.  I would be so
>>>>>>>> thankful if anyone could guide me in the right direction on how
>>>>>>>> to get
>>>> it
>>>>>> to
>>>>>>>> work.
>>>>>>>> ~Becky
>>>>>>>> MAP
>>>>>>>> IMAGETYPE      PNG24
>>>>>>>> EXTENT         -2153561.581984760 4847233.565621579
>>>>>>>> 2641846.236294404 -6178805.564371807
>>>>>>>> SIZE           800 500
>>>>>>>> SHAPEPATH      "data"
>>>>>>>> IMAGECOLOR     203 201 226
>>>>>>>> PROJECTION
>>>>>>>>  "proj=laea"
>>>>>>>>  "ellps=clrk66"
>>>>>>>>  "lat_0=45"
>>>>>>>>  "lon_0=-100"
>>>>>>>> END
>>>>>>>> # Start of LAYER DEFINITIONS
>>>>>>>> LAYER # States polygon layer begins here
>>>>>>>>  NAME         states
>>>>>>>>  DATA         STATES
>>>>>>>>  STATUS       DEFAULT
>>>>>>>>  TYPE         POLYGON
>>>>>>>>  PROJECTION
>>>>>>>>    "init=epsg:4326"
>>>>>>>>  END
>>>>>>>>  JOIN
>>>>>>>>      NAME     "Felon Ethnicity"
>>>>>>>>     TABLE    "data/FelonEthnicity.dbf"
>>>>>>>>     FROM     "STATE_NAME"
>>>>>>>>     TO     "STATE"
>>>>>>>>      TYPE     single
>>>>>>>>  END #Join
>>>>>>>>  CLASS
>>>>>>>>     NAME "<21%"
>>>>>>>>     COLOR 242 240 247
>>>>>>>>     OUTLINECOLOR 200 200 200
>>>>>>>>    COLOR        232 232 232
>>>>>>>>    OUTLINECOLOR 32 32 32
>>>>>>>>  END
>>>>>>>> END # States polygon layer ends here
>>>>>>>> # End of LAYER DEFINITIONS
>>>>>>>> END # end of map file/object
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
