[Mapserver-users] OGC WMS GetfeatureInfo - MapServer 4.2
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Fri Jul 16 11:33:55 EDT 2004
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
> Julien, Heryk
> Sent: Friday, July 16, 2004 11:10
> To: 'mapserver-users at lists.gis.umn.edu'
> Subject: RE: [Mapserver-users] OGC WMS GetfeatureInfo - MapServer 4.2
> Thanks for the clarification.
> But, I do think having "layers" and "query_layers" is a
> redundant since a GetFeatureInfo request doesn't generate a
> map. But now I understand that this is imposed by the OGC
> spec, not MapServer. BTW, thanks Tom for your course on
> MapServer's OGC configurations last spring in Ottawa. Your
> examples where very useful.
Merci beaucoup. Note that the "MapServer and OGC Services" Workshop given at OSGIS2004/MUM2 is posted on the conference proceedings page, and I will be actively updating / maintaining it as changes/updates/etc. occur in MapServer (WCS is next :)). If anyone is interested in helping out, you know where to find me.
Cheers
..Tom
Tom Kralidis
Systems Scientist
Environment Canada
Tel: +01-905-336-4409
http://www.ec.gc.ca/
> Héryk Julien
> GSC-Québec
> NRCan
> -----Message d'origine-----
> De : Daniel Morissette [mailto:dmorissette at dmsolutions.ca]
> Envoyé : 15 juillet, 2004 17:54
> À : Julien, Heryk
> Cc : mapserver-users at lists.gis.umn.edu
> Objet : Re: [Mapserver-users] OGC WMS GetfeatureInfo - MapServer 4.2
> Julien, Heryk wrote:
> > So I'm passing the same information in two different parameters
> > (Query_Layers and Layers)! In table 9 (The Parameters of a
> > GetFeatureInfo Request p.40) of the OGC specs
> > (http://www.opengis.org/docs/01-068r3.pdf) the layers param is not
> > needed in a GetFeatureInfo request.
> A GetFeatureInfo is performed by clicking on a map produced using a
> GetMap call, so you need to indicate to the server which map
> you clicked
> on, that's why you need to carry the GetMap requests.
> The parameters listed in table 9 are only those you need to
> add on top
> of the corresponding GetMap parameters. This is indicated,
> but maybe not
> clearly enough, in 7.3.1 page 39:
> "Because the WMS protocol is stateless, the GetFeatureInfo request
> indicates to the WMS what map the user is viewing by
> including most
> of the original GetMap request parameters (all but VERSION and
> REQUEST)."
> Of course LAYERS may be considered redundant in this context,
> but there
> may be contexts that I can't think of right now where it is
> useful, so
> instead of documenting a bunch of exceptions the spec just
> says: "start
> with the GetMap parameters, and add the GetFeatureInfo
> parameters on top."
> Note that in QUERY_LAYERS you should only pass the layers you want to
> query, this will often be a subset of the LAYERS parameter.
> HTH
> Daniel
> Daniel Morissette dmorissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
