[Mapserver-users] Adding a new layer gives Premture end of script headers error
Ganesh Pulicherla ganesh at cs.und.edu
Mon Jul 19 12:24:10 EDT 2004
Yes. If we remove an existing layer and add a new layer, it works fine.
Couldnt figure out what might be the problem still.
Thanks
Ganesh
Quoting Tyler Mitchell <tjmitchell at riverside.bc.ca>:
> What kind of layer was it?  Does it happen if you do a test and just copy
> an existing layer one more time?
> Tyler
> mapserver-users-admin at lists.gis.umn.edu wrote on 07/16/2004 07:49:03 AM:
> > Hello everyone,
> > We are using PHP/Mapscript(most recent Mapserver 4 version) for our
> > application
> > on RedHat Linux/Apache.
> > Everything was working fine but recently caught up with a wierd problem.
> > We have around 34 layers defined in our Map file and upon adding a
> > new layer, it
> > gives us the Internal Server error, Premture end of script headers.
> > We are not sure what the problem is and have been struggling to find the
> > solution. The documentation and forums say that we can have 100 layers
> in the
> > Map file.
> > So, no clue as to whats going on.
> > Any suggestions or help is greatly appreciated.
> > Thanks in advance.
> > Regards
> > Ganesh
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
