[Mapserver-users] null values in postgis
Kathi Koebke
koebke at zadi.de
Tue Jul 20 02:13:13 EDT 2004
Hey Vladimir,
Thank your for help. I was testing to work with the cast statement but
it dosen't work . I think there is something work in my cast statement
for postgresql and i have to check it out or to find another way,
because I don't want to take hand on the original data. Could it be a
bug in mapserver?
Hasta luego
Kathi
Vladimir Guzmán schrieb:
> I've had a simmilar problem, but with oracle, and what I did was a
> casting, for example:
> data=the_geom FROM (SELECT CASE WHEN field IS NULL THEN ' ' ELSE
> CAST(field AS VARCHAR) END AS field)
> And the expression would be:
> EXPRESSION ([field] = ' ')
> I don't know if there is a better way to do that, but it worked.
> Hope that helps,
Kathi Köbke
Projektkoordinatorin ENV
ZADI - Zentralstelle für
Agrardokumentation und -information
Villichgasse 17, D-53177 Bonn, Germany
Tel: +49 (228) 95 48 406
Fax: +49 (228) 95 48 111
E-Mail: koebke at zadi.de
http://www.zadi.de
