[Mapserver-users] Changing Colors in Map !!
Satyajit
satyajit.gantayat at aurovision.com
Wed Jul 21 02:51:00 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0002_01C46F1D.674E0E80
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hi Steve and Andy,
I tried Steve's method of adding dummy layers to my map file.
But I don't see any significant improvement in the "changing color"
problem. My map still behaves the same. I am using a lot of colors in my
map. Since I have some 39 layers in my map, there are more than 40
unique colors used in the map (outline colors also count). Do I have to
use these 40 colors in the dummy layers i.e. 40 dummy layers have to be
created ?? I tried using only 10 dummy layers with only one class in
each of them. Will my problem be solved if I use a single dummy layer
with 40 classes added in it ?
The legend problem has been solved. As Steve used HTML legend stuff, I
am also using a HTML legend stuff. Hence I have control over the legend.
I can choose which layers to be shown in the legend.
I am attaching my map file with this mail. The part of map file which
Steve has given in his mail ( which is also in the bug list at this
place http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=306) seems to be
of a different version. When I tried to copy the same to my map file it
didn't work. I just added a "Style" object in my "Class" object with
only a color entity in it. Please have a look at the map file.
Waiting for your replies.
Regards
~sat.
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of ANDY
CANFIELD
Sent: Monday, July 19, 2004 6:50 PM
To: woodbri at swoodbridge.com; satyajit.gantayat at aurovision.com
Cc: girish.shewale at aurovision.com; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Changing Colors in Map !!
Yes, I believe there is a way to do what you want. I have a legend on
the
side of my maps that I generate on the fly by looping through the layers
of
the map and adding each layer to the legend as the loop progresses as
check
boxes with the layer name so the user can turn off or on the layers.
This allows the legend to be dynamic so no matter what the layers are in
any
map I always get a uniformly formatted legend with no code changes.
I have a cosmetic layer much like the layer you are describing that I
use to
copy for placing geocoded points on the map. The users are geocoding
from
multiple text files so I want different colored points for each file so
they
can compare the results of the files. That's why I use copies of that
cosmetic layer so I can use it's symbols and only have to change the
color.
I don't want the users to have access to these cosmetic layer copies
that
are created on the fly. So I make that the first layer and my loop
through
the layers starts at layer 1 rather than layer 0 so the first layer
never
shows up in the legend. You could do the same thing with as many
cosmetic or
contruction layers as you wanted just be sure to start your loop one
beyond
the last "invisible" layer.
>From: Stephen Woodbridge <woodbri at swoodbridge.com>
>To: Satyajit <satyajit.gantayat at aurovision.com>
>CC: Girish <girish.shewale at aurovision.com>, MapServer List
><mapserver-users at lists.gis.umn.edu>
>Date: Mon, 19 Jul 2004 08:16:59 -0400
>You raise a good issue. I don't usually display legends, but have used
>HTML
>Legend stuff that allows you a lot of control over your legends and I
think
>you can eliminate layers on a named basis. which might work for you.
>Please add a comment to the bug referenced below about this problem. I
>hope
>that the developers will tackle this problem but it helps to have a
>complete picture of the problem and issues and their work arounds.
>-Steve W
>Satyajit wrote:
>>Hi Steve,
>> Thanks a lot for the info. I have not tried your method yet but
>>shall try it very soon. And let you know the result. I have a question
>>in my mind though. When we add a dummy layer in our map and add
>>classes to it ( to preserve the colors ..as you said), the layer will
>>be shown in the legend in the browser. That dummy layer in the legend
>>might confuse the end user as that layer's features won't be easily
>>visible in the map and of course that layer doesn't have much meaning
>>to it. Is there any way by which I can add that layer in my map file
>>with all the classes but still make it invisible in the legend ?
>>Thanks a lot again steve. Shall get back to you after modifying my map
>>file.
>>~sat
>>Stephen Woodbridge wrote:
>>>I think I may have created a feature and inserted a one pixel dot on
>>>the map that gets covers by later layers. Play with it and if you
>>>have a problem let me know and I can dig through old mapfiles and
>>>find out
>>how
>>>I did it.
>>Here are some examples of preserving the colors in a symbol that were
>>changing. The big problem with this approach is that it uses up a lot
of
>>layers, so you might try using one layer with lots of classes, but I'm
>>not
>>sure it that will work.
>>The bug for this problem is:
>>I just updated it with this information.
>>## dummy layer to protect symbol colors from changing
>> LAYER
>> NAME "color_symbol"
>> STATUS DEFAULT
>> TYPE point
>> TRANSFORM false
>> FEATURE
>> POINTS
>> 1 1
>> END
>> END
>> CLASS
>> SYMBOL "color_symbol"
>> COLOR 0 0 0
>> END
>> END
>>## protect other colors
>> LAYER
>> NAME blue
>> STATUS DEFAULT
>> TYPE point
>> TRANSFORM false
>> FEATURE
>> POINTS
>> 1 1
>> END
>> END
>> CLASS
>> COLOR 0 0 255
>> END
>> END
>> LAYER
>> NAME green
>> STATUS DEFAULT
>> TYPE point
>> TRANSFORM false
>> FEATURE
>> POINTS
>> 1 1
>> END
>> END
>> CLASS
>> COLOR 8 206 107
>> END
>> END
Satyajit wrote :
Dear Users,
Thanks a million to all the users who gave me their valuable
suggestions while building site. Without the help of this group it would
have been impossible for me to build such a nice site ( I hope you too
find it nice). Though my map is smoothly running, I have a strange
problem in my hands. The data layers in my map are changing colors while
browsing through them. The change in color happens randomly at some zoom
levels. At times the colors of the data layer match with the colors in
the map. You can check out this site http://203.199.114.111/newham/ .
Normally the data is shown in the color specified in the map file. But
when I try to zoom in the data layers seem to take the colors of
different other data layers. And it create a whole lot of confusion. I
can't really find any reason for this.
Any ideas ?
Sat
Sr. Specialist - GIS
name="newham.map"
Content-Transfer-Encoding: quoted-printable
Content-Disposition: attachment;
filename="newham.map"
MAP=0A=
NAME "NewHam"=0A=
STATUS ON=0A=
EXTENT 535100 178000 547000 188000 =0A=
SIZE 607 433 =0A=
SHAPEPATH "./newham"=0A=
SYMBOLSET "./etc/symbols.sym"=0A=
FONTSET "./etc/fonts.txt"=0A=
IMAGETYPE PNG=0A=
IMAGECOLOR 255 255 255=0A=
UNITS METERS=0A=
WEB=0A=
MINSCALE 100=0A=
MAXSCALE 1700000=0A=
IMAGEPATH "/tmp/ms_tmp/"=0A=
IMAGEURL "/ms_tmp/"=0A=
END=0A=
REFERENCE=0A=
STATUS ON=0A=
IMAGE "./newham/images/newham.jpg"=0A=
SIZE 141 125 =0A=
EXTENT 535100.000000 178000.220000 547000.300000 188000.150000 =0A=
COLOR -1 -1 -1=0A=
OUTLINECOLOR 255 0 0=0A=
MINBOXSIZE 3=0A=
MAXBOXSIZE 0=0A=
MARKER 0=0A=
MARKERSIZE 0=0A=
END=0A=
QUERYMAP=0A=
STATUS ON=0A=
COLOR 255 255 0=0A=
STYLE HILITE=0A=
END=0A=
LEGEND=0A=
STATUS ON=0A=
OUTLINECOLOR 153 153 153=0A=
TRANSPARENT FALSE=0A=
POSITION LL=0A=
KEYSIZE 18 12 =0A=
KEYSPACING 5 5 =0A=
TEMPLATE "ttt"=0A=
LABEL=0A=
TYPE BITMAP=0A=
SIZE MEDIUM=0A=
OFFSET 0 0 =0A=
BUFFER 0=0A=
MINDISTANCE -1=0A=
MINFEATURESIZE -1=0A=
COLOR 0 0 89=0A=
ANTIALIAS TRUE=0A=
PARTIALS TRUE=0A=
FORCE TRUE=0A=
END=0A=
END=0A=
SCALEBAR=0A=
STATUS ON=0A=
OUTLINECOLOR 0 0 0=0A=
BACKGROUNDCOLOR 0 0 0=0A=
TRANSPARENT ON=0A=
UNITS METERS=0A=
INTERVALS 2=0A=
SIZE 160 5 =0A=
STYLE 0=0A=
POSITION UC=0A=
INTERLACE ON=0A=
POSTLABELCACHE TRUE=0A=
LABEL=0A=
TYPE BITMAP=0A=
SIZE MEDIUM=0A=
OFFSET 0 0 =0A=
BUFFER 0=0A=
MINDISTANCE -1=0A=
COLOR 0 0 0=0A=
ANTIALIAS TRUE=0A=
PARTIALS TRUE=0A=
FORCE TRUE=0A=
END=0A=
END=0A=
OUTPUTFORMAT=0A=
NAME "png"=0A=
MIMETYPE "image/png"=0A=
DRIVER "GD/PNG"=0A=
EXTENSION "png"=0A=
IMAGEMODE PC256=0A=
TRANSPARENT OFF=0A=
END=0A=
# Start of Dummy Layer to protect symbol colors from changing =0A=
=0A=
## dummy layer to protect symbol colors from changing - layer one=0A=
LAYER=0A=
NAME "color_symbol"=0A=
STATUS OFF=0A=
TYPE point=0A=
TRANSFORM false=0A=
CLASS=0A=
STYLE=0A=
COLOR 178 178 178=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
=0A=
# End of dummy layer one=0A=
=0A=
## Dummy Layer to protect blue - layer two=0A=
LAYER=0A=
NAME "blue"=0A=
STATUS OFF=0A=
TYPE point=0A=
TRANSFORM false=0A=
CLASS=0A=
STYLE=0A=
COLOR 0 0 255=0A=
END=0A=
END=0A=
END=0A=
=0A=
# End of dummy layer two=0A=
=0A=
## Dummy Layer to protect red - Layer three=0A=
=0A=
LAYER=0A=
NAME "green"=0A=
STATUS OFF=0A=
TYPE point=0A=
TRANSFORM false=0A=
CLASS=0A=
STYLE=0A=
COLOR 51 153 51=0A=
END=0A=
END=0A=
END=0A=
=0A=
# End of Dummy Layer Three=0A=
=0A=
## Dummy Layer to protect color - Layer four=0A=
LAYER=0A=
NAME "four"=0A=
STATUS OFF=0A=
TYPE point=0A=
TRANSFORM false=0A=
CLASS=0A=
STYLE=0A=
COLOR 51 153 51=0A=
END=0A=
END=0A=
END=0A=
=0A=
# End of dummy layer four=0A=
=0A=
## Dummy Layer to protect color - Layer five=0A=
LAYER=0A=
NAME "five"=0A=
STATUS OFF=0A=
TYPE point=0A=
TRANSFORM false=0A=
CLASS=0A=
STYLE=0A=
COLOR 204 102 204=0A=
END=0A=
END=0A=
END=0A=
=0A=
# End of dummy layer five=0A=
=0A=
## Dummy Layer to protect color - Layer six=0A=
LAYER=0A=
NAME "six"=0A=
STATUS OFF=0A=
TYPE point=0A=
TRANSFORM false=0A=
CLASS=0A=
STYLE=0A=
COLOR 255 255 51=0A=
END=0A=
END=0A=
END=0A=
=0A=
# End of dummy layer six=0A=
=0A=
## Dummy Layer to protect color - Layer seven=0A=
LAYER=0A=
NAME "seven"=0A=
STATUS OFF=0A=
TYPE point=0A=
TRANSFORM false=0A=
CLASS=0A=
STYLE=0A=
END=0A=
END=0A=
END=0A=
=0A=
# End of dummy layer seven=0A=
=0A=
## Dummy Layer to protect color - Layer Eight=0A=
LAYER=0A=
NAME "Eight"=0A=
STATUS OFF=0A=
TYPE point=0A=
TRANSFORM false=0A=
CLASS=0A=
STYLE=0A=
COLOR 255 51 0=0A=
END=0A=
END=0A=
END=0A=
=0A=
# End of dummy layer Eight=0A=
=0A=
## Dummy Layer to protect color - Layer Nine=0A=
LAYER=0A=
NAME "Nine"=0A=
STATUS OFF=0A=
TYPE point=0A=
TRANSFORM false=0A=
CLASS=0A=
STYLE=0A=
COLOR 255 234 190=0A=
END=0A=
END=0A=
END=0A=
=0A=
# End of dummy layer Nine=0A=
=0A=
## Dummy Layer to protect color - Layer Ten=0A=
LAYER=0A=
NAME "ten"=0A=
STATUS OFF=0A=
TYPE point=0A=
TRANSFORM false=0A=
CLASS=0A=
STYLE=0A=
COLOR 78 78 78=0A=
END=0A=
END=0A=
END=0A=
=0A=
# End of dummy layer Ten=0A=
=0A=
## Dummy Layer to protect color - Layer Eleven=0A=
LAYER=0A=
NAME "blue"=0A=
STATUS OFF=0A=
TYPE point=0A=
TRANSFORM false=0A=
CLASS=0A=
STYLE=0A=
COLOR 0 0 255=0A=
END=0A=
END=0A=
END=0A=
=0A=
# End of dummy layer Eleven=0A=
=0A=
# Start of Image Group =0A=
LAYER=0A=
#NAME "Image Newham South" 28/05/04 Pradeep=0A=
NAME "IMG1"=0A=
GROUP "Street Map"=0A=
STATUS OFF=0A=
TYPE RASTER=0A=
TILEINDEX =
"../../../javasoft/maplab-2.1-rc3/tutorial/newham/IMAGES/newham_image_til=
e.shp"=0A=
TILEITEM "LOCATION"=0A=
UNITS METERS=0A=
SIZEUNITS PIXELS=0A=
TOLERANCE 0=0A=
TOLERANCEUNITS PIXELS=0A=
METADATA=0A=
"DESCRIPTION" "Newham"=0A=
END=0A=
END=0A=
# END OF IMAGE GROUP=0A=
# BEGINGING OF OS THEME GROUP=0A=
LAYER=0A=
NAME "BLDG"=0A=
GROUP "OS Themes"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
TILEINDEX =
"C:/JAVASOFT/maplab-2.1-rc3/tutorial/newham/OS_Themes/Building/Building_t=
ile.shp"=0A=
UNITS METERS=0A=
MAXSCALE 4000=0A=
LABELITEM "BLD_NO"=0A=
LABELMAXSCALE 4000=0A=
TEMPLATE "../../../msapps/gmf_apps/newham/building.html"=0A=
METADATA=0A=
"DESCRIPTION" "Building"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 7=0A=
MINSIZE 6=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 0 0 0=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 7=0A=
OUTLINECOLOR 178 178 178=0A=
SIZE 1=0A=
MINSIZE 1=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "LP"=0A=
STATUS ON=0A=
TYPE LINE=0A=
TILEINDEX =
"../../../JAVASOFT/maplab-2.1-rc3/tutorial/newham/OS_Themes/Land_Parcel/l=
and_parcel_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
MAXSCALE 4000=0A=
METADATA=0A=
"DESCRIPTION" "Land Parcels"=0A=
END=0A=
CLASS=0A=
STYLE=0A=
SYMBOL 8=0A=
SIZE 1=0A=
MINSIZE 1=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "RT"=0A=
STATUS ON=0A=
TYPE LINE=0A=
TILEINDEX =
"C:/JAVASOFT/maplab-2.1-rc3/tutorial/newham/OS_Themes/road_track/road_tra=
ck_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
MAXSCALE 25001=0A=
METADATA=0A=
"DESCRIPTION" "Road Track"=0A=
END=0A=
CLASS=0A=
STYLE=0A=
SYMBOL 1=0A=
SIZE 1=0A=
MINSIZE 1=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "RL"=0A=
STATUS ON=0A=
TYPE LINE=0A=
TILEINDEX =
"C:/JAVASOFT/maplab-2.1-rc3/tutorial/newham/OS_Themes/railway_lines/railw=
ay_lines_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 800=0A=
MAXSCALE 50000=0A=
METADATA=0A=
"DESCRIPTION" "Railway Lines"=0A=
END=0A=
CLASS=0A=
STYLE=0A=
SYMBOL "line"=0A=
SIZE 1=0A=
MINSIZE 1=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "ELECT"=0A=
STATUS ON=0A=
DATA =
"../../../../JAVASOFT/maplab-2.1-rc3/tutorial/newham/OS_Themes/electoral_=
bdy"=0A=
TYPE POLYGON=0A=
UNITS METERS=0A=
METADATA=0A=
"DESCRIPTION" "Electoral"=0A=
END=0A=
CLASS=0A=
STYLE=0A=
SYMBOL 5=0A=
OUTLINECOLOR 51 153 51=0A=
SIZE 2=0A=
MINSIZE 1=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
# CLASS=0A=
END=0A=
LAYER=0A=
NAME "PARL"=0A=
STATUS ON=0A=
DATA =
"../../../../JAVASOFT/maplab-2.1-rc3/tutorial/newham/OS_Themes/parliament=
ary_bdy"=0A=
TYPE POLYGON=0A=
UNITS METERS=0A=
METADATA=0A=
"DESCRIPTION" "Parliamentary"=0A=
END=0A=
CLASS=0A=
STYLE=0A=
SYMBOL 1=0A=
OUTLINECOLOR 204 102 204=0A=
SIZE 1=0A=
MINSIZE 1=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
# CLASS=0A=
END=0A=
LAYER=0A=
NAME "DIST"=0A=
STATUS ON=0A=
DATA =
"../../../../JAVASOFT/maplab-2.1-rc3/tutorial/newham/OS_Themes/district_b=
dy"=0A=
TYPE POLYGON=0A=
UNITS METERS=0A=
LABELITEM "NAME"=0A=
LABELMINSCALE 25000=0A=
LABELMAXSCALE 170000=0A=
METADATA=0A=
"DESCRIPTION" "District"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "fritqat"=0A=
SIZE 15=0A=
MINSIZE 10=0A=
MAXSIZE 20=0A=
OFFSET 0 0 =0A=
COLOR 255 51 0=0A=
OUTLINECOLOR 255 255 51=0A=
SHADOWCOLOR 153 153 153=0A=
END=0A=
STYLE=0A=
SYMBOL 1=0A=
OUTLINECOLOR 255 51 0=0A=
SIZE 4=0A=
MINSIZE 4=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
# CLASS=0A=
END=0A=
# END OF OS THEME GROUP=0A=
# BEGINGING OF OPEN SPACE GROUP=0A=
LAYER=0A=
NAME "OS"=0A=
GROUP "Open Space"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
TILEINDEX "C:/JAVASOFT/maplab-2.1-rc3/tutorial/newham/UDP =
themes/Open_space/Open_Space_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
LABELITEM "PROPNO"=0A=
METADATA=0A=
"DESCRIPTION" "Open Space"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 200 0 10=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 0=0A=
OUTLINECOLOR 78 78 78=0A=
SIZE 4=0A=
MINSIZE 4=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
# END OF OPEN SPACE GROUP=0A=
#BEGINING OF COMMUNITY SERVICE GROUP=0A=
LAYER=0A=
NAME "CS"=0A=
GROUP "Community Services"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Community services/Community_Services_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Community Services"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 150 100 250=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 0=0A=
COLOR 255 118 250=0A=
SIZE 4=0A=
MINSIZE 4=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
# END OF COMMUNITY GROUP=0A=
# BEGINING OF TRANSPORT GROUP=0A=
LAYER=0A=
NAME "TO"=0A=
GROUP "Transport"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Transport/Others/Others_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Transport Others"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 255 200 0=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 0=0A=
COLOR 192 108 57=0A=
SIZE 4=0A=
MINSIZE 4=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "RS"=0A=
STATUS ON=0A=
TYPE POINT=0A=
themes/Transport/Radar_Station/Radar_Station_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Radar Station"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 240 0 10=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 4=0A=
COLOR 255 255 0=0A=
SIZE 9=0A=
MINSIZE 9=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "POPAP"=0A=
STATUS ON=0A=
TYPE POINT=0A=
themes/Transport/protection_public_access/protection_public_access_tile.s=
hp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Protection of Public Access Points"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 0 112 255=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 4=0A=
COLOR 255 255 0=0A=
SIZE 7=0A=
MINSIZE 7=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "POFW"=0A=
STATUS ON=0A=
TYPE POINT=0A=
themes/Transport/protection_freight_wharf/protection_freight_wharf_tile.s=
hp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Protection of Freight Wharf"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 200 50 10=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 12=0A=
COLOR 255 255 0=0A=
SIZE 6=0A=
MINSIZE 6=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "POMP"=0A=
STATUS ON=0A=
TYPE POINT=0A=
themes/Transport/protection_mooring_points/protection_mooring_points_tile=
.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Protection of Mooring Points"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 10 130 0=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 7=0A=
COLOR 255 255 0=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "PCP"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Transport/Proposed_car_park/Proposed_car_park_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Proposed Car Park"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 230 122 122=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 0=0A=
COLOR 168 56 0=0A=
SIZE 4=0A=
MINSIZE 4=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "CN"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Transport/Cycle_network/Cycle_network_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Cycle Network"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 170 0 10=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 10=0A=
COLOR 255 127 127=0A=
OUTLINECOLOR 255 127 127=0A=
SIZE 4=0A=
MINSIZE 4=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "RFoot"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Transport/Recreational_footpath/Recreational_footpath_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Recreational Footpath"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 240 0 10=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 1=0A=
SIZE 2=0A=
MINSIZE 2=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "CPZ"=0A=
STATUS ON=0A=
TYPE POINT=0A=
themes/Transport/Controlled_parking_zone/Controlled_parking_zone_tile.shp=
"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
TEMPLATE "ttt"=0A=
METADATA=0A=
"DESCRIPTION" "Controlled Parking Zone"=0A=
END=0A=
CLASS=0A=
TEMPLATE "ttt"=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 90 0 10=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 13=0A=
COLOR 168 112 0=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "DLRAE"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Transport/Dlr_extension/Dlr_extension_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "DLR Airport Extension"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 170 0 230=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 0=0A=
COLOR 240 0 10=0A=
SIZE 8=0A=
MINSIZE 7=0A=
MAXSIZE 10=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "JRI"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Transport/Junction_road_improvement/Junction_road_improvement_tile=
.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Junction Road Improvement"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 38 140 0=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 1=0A=
OUTLINECOLOR 255 170 0=0A=
SIZE 2=0A=
MINSIZE 2=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "OTL"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Transport/Other_transport_link/Other_transport_link_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Other Transport Link"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 240 0 10=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 0=0A=
COLOR 255 255 115=0A=
SIZE 4=0A=
MINSIZE 4=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "NRoad"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Transport/New_road/New_road_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "New Road"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 0 169 230=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 1=0A=
OUTLINECOLOR 255 255 115=0A=
SIZE 4=0A=
MINSIZE 4=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "RSLine"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Transport/Rail_safeguarding_line/Rail_safeguarding_line_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Rail Safeguarding Line"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 61 255 64=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
COLOR 57 167 146=0A=
SIZE 4=0A=
MINSIZE 4=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "SRefurb"=0A=
STATUS ON=0A=
TYPE POINT=0A=
themes/Transport/Station_Refurbishment/Station_Refurbishment_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Station Refurbishment"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 230 70 0=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 2=0A=
COLOR 56 168 0=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "NStat"=0A=
STATUS ON=0A=
TYPE POINT=0A=
themes/Transport/New_Station/New_Station_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "New Station"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 240 230 10=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 4=0A=
COLOR 115 0 0=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "LCASZ"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Transport/London_city_airport_safety/London_city_airport_safety_ti=
le.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "London City Airport Safety Zone"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 230 0 169=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 10=0A=
COLOR 0 0 0=0A=
SIZE 13=0A=
MINSIZE 13=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
# END OF TRANSPORT GROUP=0A=
# BEGINGING OF LEISURE AND RECREATION GROUP=0A=
LAYER=0A=
NAME "L&R"=0A=
GROUP "Leisure & Recreation"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Leisure_recreation/Leisure_recreation_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Leisure & Recreation"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 255 0 197=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 0=0A=
COLOR 255 192 232=0A=
SIZE 4=0A=
MINSIZE 4=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
# END OF LEISURE AND RECREATION GROUP=0A=
# BEGINING OF SHOPPIONG AND TOWN CENTER GROUP=0A=
LAYER=0A=
NAME "TCent"=0A=
GROUP "Shopping and Town Centers"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Shopping and Town Centers/Town Centres/Town_Centres_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Town Centres"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 240 0 10=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 1=0A=
OUTLINECOLOR 115 0 0=0A=
SIZE 3=0A=
MINSIZE 3=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "SOth"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Shopping and Town =
Centers/Shopping_Others/Shopping_Others_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Shopping Others"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 20 0 135=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 0=0A=
COLOR 0 197 255=0A=
SIZE 4=0A=
MINSIZE 4=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "RDev"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
Centers/retail_development/retail_development_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Retail Development"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
COLOR 0 0 255=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 0=0A=
COLOR 190 232 255=0A=
SIZE 4=0A=
MINSIZE 4=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
# END OF SHOPPIONG AND TOWN CENTER GROUP=0A=
# BEGINING OF EMPLOYMENT GROUP=0A=
LAYER=0A=
NAME "Emp"=0A=
GROUP "Employment"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Employment/Employment_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Employment"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 255 51 0=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 0=0A=
COLOR 255 229 237=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
# END OF EMPLOYMENT GROUP=0A=
# BEGINING OF HOUSING GROUP=0A=
LAYER=0A=
NAME "RArea"=0A=
GROUP "Housing"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Housing/Renewal_area/Renewal_area_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Renewal Area"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 1=0A=
OUTLINECOLOR 255 0 197=0A=
SIZE 2=0A=
MINSIZE 2=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "Dwel"=0A=
GROUP "Housing"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Housing/Dwellings/Dwellings_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Dwellings"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 14=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 0 51 255=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 0=0A=
COLOR 255 216 110=0A=
SIZE 4=0A=
MINSIZE 4=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
# END OF HOUSING GROUP=0A=
# BEGINING OF ENVIRONMENTAL QUALITY GROUP=0A=
LAYER=0A=
NAME "SOSF"=0A=
GROUP "Environmental Quality"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Environmental =
quality/safeguarding_of_site_facilities/safeguarding_of_site_facilities_t=
ile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Safeguarding of Site Facilities"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 255 153 153=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 10=0A=
COLOR 56 168 0=0A=
OUTLINECOLOR 56 168 0=0A=
SIZE 2=0A=
MINSIZE 2=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "PWood"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
quality/Proposed_woodland/Proposed_woodland_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Proposed Woodland"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 14=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 255 102 255=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 6=0A=
COLOR 0 0 0=0A=
SIZE 4=0A=
MINSIZE 4=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "PSONCI"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
quality/Site_of_Nature_Conservation_Importance/Site_of_Nature_Conservatio=
n_Importance_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Protected Site of Nature Conservation Importance"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 0 150 235=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 7=0A=
COLOR 56 168 0=0A=
SIZE 1=0A=
MINSIZE 1=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
# END OF ENVIRONMENTAL QUALITY GROUP=0A=
# BEGINGING OF URBAN REGENERATION GROUP=0A=
LAYER=0A=
NAME "MUse"=0A=
GROUP "Urban Regeneration"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Urban_Regeneration/Mixed Use/Mixed_Use_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
METADATA=0A=
"DESCRIPTION" "Mixed Use"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Arial"=0A=
SIZE 10=0A=
MINSIZE 10=0A=
MAXSIZE 15=0A=
POSITION CC=0A=
OFFSET 0 0 =0A=
ANGLE AUTO=0A=
COLOR 255 87 20=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 0=0A=
COLOR 130 130 130=0A=
SIZE 2=0A=
MINSIZE 2=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
LAYER=0A=
NAME "MOpp"=0A=
STATUS ON=0A=
TYPE POLYGON=0A=
themes/Urban_Regeneration/Major =
Opportunities/Major_Opportunities_tile.shp"=0A=
UNITS METERS=0A=
MINSCALE 200=0A=
#31/05/04 Pradeep=0A=
METADATA=0A=
"DESCRIPTION" "Major Opportunities"=0A=
END=0A=
CLASS=0A=
LABEL=0A=
TYPE TRUETYPE=0A=
FONT "Verdana"=0A=
SIZE 10=0A=
POSITION AUTO=0A=
OFFSET 0 0 =0A=
COLOR 0 51 153=0A=
ANTIALIAS TRUE=0A=
END=0A=
STYLE=0A=
SYMBOL 1=0A=
OUTLINECOLOR 137 90 68=0A=
SIZE 3=0A=
MINSIZE 3=0A=
MAXSIZE 100=0A=
ANTIALIAS TRUE=0A=
END=0A=
END=0A=
END=0A=
# END OF URBAN REGENERATION=0A=
END=0A=
------=_NextPart_000_0002_01C46F1D.674E0E80--
