[Mapserver-users] Mapinfo
warjac warjac
warjac_warjac at hotmail.com
Wed Jul 21 06:21:08 EDT 2004
Hello
I need some critic because it does not work with this config
Winsdows XP
C:\>PATH
PATH=C:\Programme\Microsoft
Office\Office;C:\Perl\bin\;C:\MapServer\lib;c:\foxse
rv\perl;c:\foxserv\apache\cgi-bin;c:\proj\bin.;C:\WINDOWS\system32;c:\OpenEV_FW_
174\openev_fw\bin.;C:\WINDOWS;C:\WINDOWS\System32\Wbem
MapServer Config:
C:\>mapserv -v
MapServer version 4.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF
OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLI
ENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
OGRINFO
c:\foxServ\www\workshop\data\GERMANY\WIESBADN>ogrinfo A_WIESBA_WGS84.TAB
Had to open data source read-only.
INFO: Open of `A_WIESBA_WGS84.TAB'
using driver `MapInfo File' successful.
1: A_WIESBA_WGS84 (Polygon)
ogrinfo
Layer name: A_WIESBA_WGS84
Geometry: Polygon
Feature Count: 60
Extent: (8.111737, 49.978662) - (8.385932, 50.152873)
Layer SRS WKT:
GEOGCS["unnamed",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563],
TOWGS84[0,0,0,0,0,0,0]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]]
WIESBADN.MAP file
NAME "WIESBADN"
SIZE 500 500
STATUS ON
EXTENT 8.095711 50.023119 8.392355 50.155013 #Extend must be given inorder
to Calulate
UNITS DD #Needed for center Calulation
# Map projection definition
PROJECTION
"proj=latlong" "ellps=WGS84" #Case sensitive
END #PROJECTION
WEB
IMAGEPATH "set in index.html"
#c:\foxserv\www\workshop\data\GERMANY\WIESBADN\tmp
IMAGEURL "set in index.html"
LOG "/foxserv/www/workshop/tmp/gmap.log"
TEMPLATE "WIESBADN_basic.html"
MINSCALE 0
MAXSCALE 8900000
END #WEB
LAYER
NAME A_WIESBA
TYPE POLYGON
CONNECTIONTYPE OGR
CONNECTION "c:\foxserv\www\workshop\data\GERMANY\WIESBADN\A_WIESBA.TAB"
STATUS ON
STYLEITEM "AUTO"
END #LAYER
#CLASSITEM "A_WIESBA" #Does not work with this configuration
#CLASS
#NAME "A_WIESBA"
#COLOR 0 254 140
#END #Class
END #MAP
Log files
c:\foxserv\www\workshop\tmp\gmap.log
Wed Jul 21 11:28:25 2004,3176,192.168.1.104,WIESBADN,0,8.140208 49.967960
8.436852 50.264788,8.288530 50.116374,,normal execution
c:\foxserv\Apache\log\error.log
[Wed Jul 21 11:28:26 2004] [error] [client 192.168.1.104] File does not
exist:
c:/foxserv/www/workshop/data/germany/wiesbadn/tmp/wiesbadnref10904021053176.gif
c:\foxserv\Apache\log\Access.log
HTTP/1.1" 404 4667
"GET /cgi-bin/mapserv.exe?
mode=browse&zoomdir=1&zoomsize=2&imgxy=249.5+249.5&imgext=8.219708+50.060571+8.368030+50.208985&
map=C%3A%5CFoxServ%5Cwww%5Cworkshop%5Cwiesbadn.map&root=%2Fworkshop&savequery=true&program=%2
Fcgi-bin%2Fmapserv.exe&map_web_imagepath=C%3A%5CFoxServ%5Cwww%5Cworkshop%5Cdata%5C
GERMANY%5CWIESBADN%5Ctmp%5C&map_web_imageurl=%2Fworkshop%2Fdata%2FGERMANY%2FWIESBADN%2Ftmp%2F&
map_web_template=WIESBADN_basic.html HTTP/1.1" 200 3163
"GET /workshop/data/GERMANY/WIESBADN/tmp/WIESBADN10904028673580.gif
HTTP/1.1" 200 799
"GET /workshop/data/GERMANY/WIESBADN/tmp/WIESBADNleg10904028673580.gif
HTTP/1.1" 404 4667
"GET /workshop/data/GERMANY/WIESBADN/tmp/WIESBADNsb10904028673580.gif
HTTP/1.1" 404 4667
"GET /workshop/data/GERMANY/WIESBADN/tmp/WIESBADNref10904028673580.gif
HTTP/1.1" 404 4667
Approximatly 1KB
C:\FoxServ\www\workshop\data\GERMANY\WIESBADN\tmp>21.07.2004 11:41 799
>From: "Flavio Hendry" <flavio at tydac.ch>
>To: "warjac warjac" <warjac_warjac at hotmail.com>,
>mapserver-users at lists.gis.umn.edu, Gunter.Hahn at datagis.com
>Subject: Re: [Mapserver-users] Mapinfo
>Date: Tue, 20 Jul 2004 16:36:42 +0200
>Hi
>it's fairly simple and you don't have to "import" anything, it's read
>directly; chunck of mapfile (be aware that the shapepath is not used,
>so enter a relative path or an absolte path to your mapinfo files):
>LAYER
> NAME "Nutzungszonen"
> TYPE POLYGON
> MINSCALE 0
> MAXSCALE 100000
> STATUS ON
> CONNECTIONTYPE OGR
> CONNECTION "..\data\rp\Nutzungszonen_Nutzung.TAB"
> HEADER "ZonenArt ZonenKuerzel"
> STYLEITEM "AUTO"
> CLASS
> NAME "Nutzungszonen_Nutzung"
> TEMPLATE ttt.htm
> END # Class section
>END
>Mit freundlichem Gruss / Best Regards
>Flavio Hendry
>TYDAC NEWS http://www.tydac.ch/german/index.php?menu=News_actual
>############ Mit freundlichen Gruessen / Kind Regards
>############ mailto:flavio at tydac.ch
>############ TYDAC AG - http://www.tydac.ch
>#### #### Geographic Information Solutions
>#### #### Luternauweg 12 -- CH-3006 Bern
>############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
_________________________________________________________________
Schluß mit Spam! http://www.msn.de/antispam/prevention/junkmailfilter Wir
helfen Ihnen, unerwünschte E-Mails zu reduzieren.
