[Mapserver-users] Sensor Web Enablement (SWE), YSI and MapServer
Gerry Creager N5JXS gerry.creager at tamu.edu
Wed Jul 21 10:02:58 EDT 2004
I'm starting to take an interest in SWE at OGC.  And since I've got a
fairly extensive site (http://mesonet.tamu.edu/currentwx.html) for
sensor data it'd make sense:-)
We're currently doing WMS and if I can get time to upgrade to 4.2, we'll
be doing WFS.  That's the approach I recommend, too.
I'd be willing to start writing up something for a wiki addition on
sensor data acquisition, but I suspect it's really low-level stuff to
most of the folks here.
Data structure determination is a big player.  It's also often something
that's not done by design, but initiated by accident and improved
iteratively ina crisis management manner.  This from experience,
although we did start with a design.  Really.  I mean it!
If there's interest, I'll expand further.  There are others here doing
the same sorts of things...
gerry
Kralidis,Tom [Burlington] wrote:
> Hi Yves,
> Quite simply, UMN MapServer currently does not support the OGC SWE
> approaches.  Most OGC SWE approaches are in discussion paper form and
> not adopted OGC specifications.  I would love to see MapServer support
> OGC SWE, once OGC SWE specs are publically adopted.
> If you want to do this with UMN MapServer, my initial suggestion is
> setup as OGC:WMS and OGC:WFS.  This is what we've done with some of our
> water quality monitoring data with UMN MapServer.  We do have OGC:SCS of
> some of our sensor stuff, deployed with a commercial solution.
> Hope this helps.
> ..Tom
> Tom Kralidis
> Systems Scientist
> Environment Canada
> Tel: +01-905-336-4409
> http://www.ec.gc.ca/
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Yves
> Moisan
> Sent: Tuesday, July 20, 2004 10:49
> To: Mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] Sensor Web Enablement (SWE), YSI and
> MapServer
> Hi All,
> One of the objectives I had attending the recent OGIS conference,
> besides getting to know you all, was to understand how to
> store/retrieve/process in situ sensor data, in my particular case water
> quality data coming from YSI 6600 sondes, and deliver it in a map over
> the web.  I wanted to be able to draw the envelope of the "data service
> tier" vs any client app, because I want to build my own client without
> bundling the data tier into it.  Data must remain accessible to other
> parties and of course MapServer/Server is where the data tier ends.  At
> the time, I figured MapServer could spew out maps with little dots
> showing sensor locations, people click on the dots, get the data in
> tabular format.  Standard stuff.  I hadn't thought of sensor data
> *standard storage* per se, though.
> I am currently developing a small Python utility to gobble up YSI 6600
> sonde data.  For now, I want to be able to simulate sonde data using a
> "data generator" that would write such binary files for the sake of
> having a system pseudo-working.  We are not getting a sonde any time
> soos, but I want to get going.  When I get a sensor working, then I want
> to use such a utility to QA sensor data and potentially to view it in
> environments such as SciPy.  I don't want to use YSI's Ecowatch, at
> least not in a production environment.  The data format is binary and as
> of yet I have no clue as to how to decypher it, so I am playing around
> with the file.  BTW, anyone knows of a "binary file explorer" type of
> thing that would try and find patterns in arbitrary binary files and
> suggest data extraction schemes, e.g. firts 4 bytes are chars, next 600
> are floats ... ?
> Anyhow, the jist of this message is about the SWE initiative -- which I
> have just found out about today -- and its relation to MapServer.  I was
> hoping to store sensor data in a sort of staging environment.  At the
> first level, the original .DAT files.  At the second level, the data
> would be stored in more pallatable formats for HTML/SVG output and it
> would have been QA'd.  For that last level, I am not sure I would want
> to serialize the data in XML (but then, maybe yes!) before stuffing it
> in a DB.  Since I am using Python, I thought maybe of pickling it to a
> flat file.  That would allow me to write a QA module (checking for NaN's
> etc.) in Python and that would also let me use Python XML serialization
> modules to pipe it through (using mod_python ?) before sending out to
> the Web.  That's the flatfile/ObjectDB option.  Another would be to use
> the flat file for QA, then spew the results out in tabular format into
> PostGIS.  That'a probably closest to what would be amenable to MapSever.
> What is the status of SWE in the context of MapServer ?  I gather SWE it
> is not a spec yet, but is it coming strong?
> The point is simple : I have sensor data that I want to show up on a map
> and above all store it so it can be "OGC Serviced" when SWE clients
> start to appear.  I'll probably have to write a SWE client.  If I do, I
> want to do it with Python (thanx Sean for that point on your slide, but
> I was already convinced!) and I'll want an adapter for Zope and maybe
> Twisted (also my problem).  I just want to do it in the most "OGC
> compliant", Pythonic way.
> Any pointers ideas out there ?
> Thanx
> Yves Moisan
> Mapserver-users mailing list
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
