[Mapserver-users] How to get X and Y pixel coordinates with JavaScript
Merlos merlos at tsc.uvigo.es
Thu Jul 22 05:47:49 EDT 2004
Thank you, Pierre, Paul and Jan
I've tryed using the code below, and it works on IE and mozilla, but not in
Pocket Internet Explorer, I found the Object model of this browser and does
not support many of the properties used on the code you sent.
Regards. Juan.
On Wednesday 21 July 2004 17:27, Jan Hartmann wrote:
> Merlos wrote:
> > 	Maybe someone can help me. I was wondering if when an user clicks on the
> > image that is on an <input type="image"> element it is possible to
> > capture the X and Y coordinates before the submission is done. I mean:
> > <script type="text/javascript">
> > function formSubmit() {
> > //Here get the X and Y coords in pixels... Is it possible? How?
> > <form name="apatruyando" action="JavaScript:formSubmit()">
> > <input type="image" src="image_url.png" />
> > </form>
> Hi Merlos,
> The following works for IE5.5 and up and Netscape6/Mozilla. Not sure
> about others.
> function getCrd(e) {
>    if (document.all) {
>       X = e.clientX + document.body.scrolLeft
>       Y = e.clientY + document.body.scrolTop
>    } else {
>       X = e.clientX + window.scrollX
>       Y = e.clientY + window.scrollY
>     ... ///anything else you want to do
> If you have an image defined as:
> <img src=ïmage_url.png id=myImgId>
> you can assign this function to it by:
> var myImg = document.getElementById("myImgId")
> myImg.onmousedown = getCrd   //NB *without* parentheses
> Now every time you click somewhere in the image, the function will
> compute the coordinates of the click and execute everything else. You
> don't need to encapsulate the image in a form this way.
> This way, the coordinate is computed from the top left corner of the
> page, even if the page is scrolled. If you want the coordinate relative
> to the image, regardless where this is on the screen, you need to
> compute the top left corner of the image:
> var node = myImg
> var left = node.offsetLeft
> var top = node.offsetTop
> while (node.parentNode) {
>     node = node.parentNode
>     if (node.offsetLeft) {
>        left = left + node.offsetLeft
>        top = top + offsetTop
> Hope this helps,
> Jan
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
http://www.merlos.biz
