[Mapserver-users] quadtree indexes (qix)
bartvde at xs4all.nl
Thu Jul 22 05:52:17 EDT 2004
Hi list,
I have just been playing around a bit with quadtree index on shapefiles
which are used in an OGR tile index type of layer.
I found out with filemon that Mapserver just appends .qix behind the
filename, without removing any already present file extension.
E.g. I had the following in my LAYER definition:
TILEINDEX "tile.shp"
Which made Mapserver look for the index tile.shp.qix.
So I changed this into:
TILEINDEX "tile"
But also the location attribute of the tileindex shapefile had the
following in there (generated with ogrtindex):
f:\data\top10vector\bart0.shp,0
Which I had to change to:
Maybe the function to get the name of the quadtree index file can be
changed or the documentation could include a description of this
behaviour.
Best regards,
Bart
