[Mapserver-users] [jBox] Image dragging with PNG output
Richard Greenwood
rich at greenwoodmap.com
Thu Jul 22 10:36:20 EDT 2004
Only problem is if you have users who will be using Microsoft Internet
Explorer with the Microsoft Java VM, because it does not support PNG
image display. That is where you need jBoxPNG.
Let me know if you learn more.
Regards,
Rich
ludovic gnemmi wrote:
> Hi Rich,
> Yes ! Now image dragging works with PNG output when i
> use jBox.jar instead of jBoxPNG.jar and png.jar.
> (Works also with gif and jpeg output).
> Thanks a lot !!!
> Ludovic
> --- Richard Greenwood <rich at greenwoodmap.com> a
> écrit : > I can not reproduce your problem. The only
>>difference between my test
>>system and yours seems to by that my Java VM is
>>1.4.2_02 and yours is
>>1.4.2_04, and I really do not think that is the
>>problem.
>>Sun Java 1.4.x can display PNG images without
>>sixlegs. In other words,
>>you do not need to use jBoxPNG.jar with Java 1.4.x.
>>So could you test
>>your application with just jBox.jar and also test
>>with GIF or JPEG
>>instead of PNG?
>>Regards,
>>Rich
>>>Richard,
>>>Thanks a lot for your answer.
>>>I'm using JBoxPNG.jar (2004-06-15) and png.jar
>>>(2004-06-19) as mentioned in the jBox howto 4.2.
>>>Versions return by 'document.jBox.version()' are
>>jBox
>>>1.1.1 and Java VM 1.4.2-04.
>>>Ludovic
>>>écrit : > ludovic gnemmi wrote:
>>>>>Hi all,
>>>>>I'm testing the jBox applet...all works fine
>>>>except
>>>>>image dragging with PNG output.
>>>>>Has anybody got an idea to solve my problem?
>>>>>Ludovic Gnemmi
>>>>>DESS DCISS
>>>>Are you using jBoxPNG.jar, or native PNG support
>>>>with jBox.jar? What is
>>>>the date of the jar file? And what Java VM
>>version?
>>>>jBox has a version function,
>>>> document.jBox.version();
>>>>which should return the jBox version and the Java
>>VM
>>>>version.
>>>>Regards,
>>>>Richard Greenwood
>>>>www.greenwoodmap.com
Richard Greenwood
