[Mapserver-users] HELP {Scanned}
GONZALEZ, Jose A. JGONZALE at ABC-USA.org
Thu Jul 22 15:03:26 EDT 2004
The mapserv -v produces OUTPUT=WBMP,  which is interesting because I've
compiled with png support and both GD and mapserv seem to find the
libraries fine.  The MakeFile has GD= -DUSE_GD_GIF -DUSE_GD_PNG
-DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR.
Any help with this would be great.  Thanks Guys. - Joe
-----Original Message-----
Sent: Thursday, July 22, 2004 3:58 AM
To: GONZALEZ, Jose A.
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] HELP {Scanned}
Check wheather PNG output is supported on your istallation.
Run mapserv -v command to see the supported input and output. If you
cant see OUTPUT=PNG then you should install the neccessary libs for png
and reconfigure/compile mapserver or change the IMAGETYPE in your map
file to one of the supperted formats (GIF, JPG, ...).
Bye
Zoltan
On Wed, 21 Jul 2004, GONZALEZ,  Jose A. wrote:
> I need help with a new setup of mapserver.  I have installed all the
> components and can't seem to run the demo file.  I keep getting g the
> error:
> msPostMapParseOutputFormatSetup(): General error message. Unable to
> select IMAGETYPE 'PNG'.
> I've searched all the archives and can't find any solution.  Please
> let me know if you have seen this error before and have a solution for
> it. Thanks - Joe
