[Mapserver-users] Built but can't run : libproj not
Vladimir Guzmán bigfoot at main-task.com
Thu Jul 22 18:48:58 EDT 2004
Eduardo Patto Kanegae wrote:
> I'm configuring MapServer 4.2.1 under Linux Fedora Core 2 using:
> ./configure --enable-ignore-missing-data --enable-debug
> --with-freetype=/usr/lib --with-zlib=/usr/lib --with-png=/usr/lib
> --without-jpeg --with-xpm=/usr/X11R6/lib --with-gd=/usr --with-eppl
> --with-proj --with-ogr=/usr/local/bin/gdal-config
> --with-gdal=/usr/local/bin/gdal-config --without-tiff
> --without-postgis --without-mygis --with-wfs --with-wfsclient
> --with-wms --with-wmsclient --with-curl=/usr/bin
> --with-php=/usr/local/mapserver4linux/php-4.3.7 2>&1 | tee configure.log
> then building using
> make 2>&1 | tee make.log
> Logfiles are attached
> But after all, when trying to test all using:
> ./mapserver -v
> I got the error:
> ./mapserv: error while loading shared libraries: libproj.so.0: cannot
> open shared object file: No such file or directory
> I also tried --with-proj=/usr/local or --with-proj=/usr/local/lib ,
> but they all gave the same error.
> My PROJ 4.4.8 was built using defaul:
> ./configure
> make
> make install
> and here's the result of a  ` ls -lh /usr/local/lib/libproj*  `
> -rw-r--r--  1 root root 2.5M Jul 21 09:28 /usr/local/lib/libproj.a
> -rwxr-xr-x  1 root root  709 Jul 21 09:28 /usr/local/lib/libproj.la
> lrwxrwxrwx  1 root root   16 Jul 21 09:28 /usr/local/lib/libproj.so ->
> libproj.so.0.4.2
> lrwxrwxrwx  1 root root   31 Jul 22 18:29 /usr/local/lib/libproj.so.0
> -> /usr/local/lib/libproj.so.0.4.2
> -rwxr-xr-x  1 root root 1.4M Jul 21 09:28 /usr/local/lib/libproj.so.0.4.2
> What could be wrong?
> ps.: I can supress PROJ4 support cause I need WMS/WFS features
Is /usr/local/lib in your /etc/ld.so.conf ?
If not, put it, and run ldconfig
Hope that helps,
Vladimir Ilich Guzmán R.
http://maintask.com
